Steffan
A couple of days ago you wrote "...adding to Pmail on your PC a maibox that physically resides on
 your USB stick. Once you've done that, you can develop an intricate
system of mail filtering rules to move/copy the mail from the folder on
your USB stick to the Pmail folders on your PC. I must admit that I
totally love this feature."
I would love to be able to replicate this feature. But to see my usb stick via Pegasus on my PC, I need a few simple guidelines. Are you able to help, please?
There was a suggestion from Caisson that the explanation would be found in Folder Manager/Folders Menu. If it is there, I'm afraid it must be well camouflaged!
Thanks, in anticipation
Johnny
        <p>Steffan</p><p>A couple of days ago you wrote <i>"...adding to Pmail on your PC a maibox that physically resides on
totally love this feature.</i>"
</p><p>I would love to be able to replicate this feature. But to see my usb stick via Pegasus on my PC, I need a few simple guidelines. Are you able to help, please? </p><p>There was a suggestion from Caisson that the explanation would be found in Folder Manager/Folders Menu. If it is there, I'm afraid it must be well camouflaged!</p><p>Thanks, in anticipation</p><p>Johnny
</p><p>&nbsp;</p>
