Mercury mail problem
PaulW - Four years ago I was playing with XAMPP and at that time it was not intended for use in a production environment.
I switched to new Mercury and have problems with the mailing system.As far as I have:
Installed XAMPP (Apache, MySQL and Mercury run),everything on my PC that I want to use as a server.Then I got my fixed IP assigned to the domain.Until now everything was OK.
But now ... I try on my side http://localhost/joomla/administrator/  to send email to admin(Super Admin) and the admin could not get email from Users in another side the users can't get emails from admin
Mailer: SMTP Server
Mail-From: admin@localhost.com
sendmail-path: /usr/sbin/sendmail
auth: no
SMTP-User: (leer)
SMTP-Pass: (leer)
SMTP-Host: localhost!
My question specifically:
Do I have something set up at Mercury?How is it stored my email?I did not have much experience with email servers, ne still fail the message I got: Could not instantiate mail functio
please help
<p>Hello,</p><p><span id="result_box" class="" lang="en"><span class="hps">I switched</span> <span class="hps">to</span> <span class="hps">new</span> Mercury <span class="hps">and have</span> <span class="hps">problems</span> <span class="hps">with the</span> <span class="hps">mailing</span> <span class="hps">system</span></span>.<span id="result_box" class="short_text" lang="en"><span class="hps">As far as</span> <span class="hps">I have:</span></span></p><p><span id="result_box" class="short_text" lang="en"><span class="hps">Installed</span> <span class="hps">XAMPP</span> <span class="hps">(Apache</span><span>, MySQL and</span> <span class="hps">Mercury</span> <span class="hps">run</span><span class="">),everything</span></span><span id="result_box" class="" lang="en"><span class="hps"></span> <span class="hps">on my</span> <span class="hps">PC that</span> <span class="hps">I want to use</span> <span class="hps">as a server.</span></span><span id="result_box" class="short_text" lang="en"><span class="hps">Then I</span> <span class="hps">got my</span> <span class="hps">fixed IP</span> <span class="hps">assigned to</span> <span class="hps">the domain.</span></span><span id="result_box" class="short_text" lang="en"><span class="hps">Until now</span> <span class="hps">everything</span> <span class="hps">was</span> <span class="hps">OK</span><span class="">.</span></span></p><p><span id="result_box" class="" lang="en"><span class="hps">But</span> <span class="hps">now</span> <span class="hps">...</span> <span class="hps">I try</span> <span class="hps">on</span> <span class="hps">my side</span> http://localhost/joomla/administrator/  <span class="hps"></span><span class="hps"></span></span> to send email to admin(Super Admin) and the admin could not get email from Users in another side the users can't get emails from admin </p><p>Mailer: SMTP Server Mail-From: admin@localhost.com Name: bel.name sendmail-path: /usr/sbin/sendmail auth: no SMTP-User: (leer) SMTP-Pass: (leer) SMTP-Host: localhost! </p><p><span id="result_box" class="short_text" lang="en"><span class="hps">My question</span> <span class="hps">specifically:</span></span></p><p><span id="result_box" class="short_text" lang="en"><span class="hps">Do I have</span> <span class="hps">something</span> <span class="hps">set up</span> <span class="hps">at Mercury</span><span class="">?</span></span><span id="result_box" class="short_text" lang="en"><span class="hps">How is</span> <span class="hps">it stored</span> <span class="hps">my email</span><span class="">?</span></span><span id="result_box" class="short_text" lang="en"><span class="hps">I did</span> <span class="hps">not have much experience</span> <span class="hps">with email</span> <span class="hps">servers</span><span class="">,</span></span><span id="result_box" class="short_text" lang="en"><span class="hps"> </span></span><span id="result_box" class="short_text" lang="en"><span class="hps">ne</span> <span class="hps">still</span> <span class="hps">fail</span> <span class="hps">the</span> <span class="hps">message</span> <span class="hps">I got: </span></span>Could not instantiate mail functio</p><p><span id="result_box" class="short_text" lang="en"><span class="hps">please help</span></span> </p>
Is Mercury at all running? If so you can get a lot of information from console windows and from log files. If you want us to help you will need to provide information about the environment (Windows version, path where Mercury is installed), and preferably post the contents of the configuration file MERCURY.INI.
There is a lot of information in the built-in help system, and I recommend reading relevant parts of the PDF manual (man-473.pdf in the Mercury directory).
<p>Is Mercury at all running? If so you can get a lot of information from console windows and from log files. If you want us to help you will need to provide information about the environment (Windows version, path where Mercury is installed), and preferably post the contents of the configuration file MERCURY.INI.</p><p>There is a lot of information in the built-in help system, and I recommend reading relevant parts of the PDF manual (man-473.pdf in the Mercury directory).</p><p>/Rolf </p>
Thnx for your replay! Yes,Mercury is all running!Windows version:Microsoft Windows XP Professional Version 2002 Service Pack2,the path where Mercury is installed is C:\MERCURY and path from XAMPP is C:\xampp.configuration from file MERCURY.INI. is
#  Sample Bindery Mode / Standalone Mode MERCURY.INI file.
#  This sample file implements most of the possible switches for each
#  module, but you can edit it to do less if you wish.
#  Anything after a '#' to the end of the line is a comment and
#  is stripped out before parsing. Trailing and leading whitespace
#  is also stripped before parsing. Many sample commands have been
#  left in this file commented out for reference purposes.
#  Note that in general, manual modification of this file is NOT
#  RECOMMENDED - use the Mercury "Configuration" menu to change the
#  program's settings wherever possible.
[General]
myname:      https://127.0.0.1  # Canonical name for this server
timezone:    +0000         # Time Zone to add to date fields
file_api:    1                    # Use the file api instead of queues
mailqueue:   C:\MERCURY\QUEUE   # Where mail should be put for delivery
smtpqueue:   C:\MERCURY\QUEUE   # Where the SMTP client should look for mail
newmail_path: C:\MERCURY\MAIL\~N
[Protocols]
C:\MERCURY\mercurys.dll
C:\MERCURY\mercuryc.dll
C:\MERCURY\mercuryp.dll
C:\MERCURY\mercuryd.dll
C:\MERCURY\mercuryx.dll
C:\MERCURY\mercuryf.dll
C:\MERCURY\mercuryh.dll
C:\MERCURY\mercuryw.dll
C:\MERCURY\mercuryi.dll
C:\MERCURY\mercuryb.dll
[Mercury]
failfile:     C:\MERCURY\Mercury\FAILURE.MER  # Delivery failure notification template
confirmfile:  C:\MERCURY\Mercury\CONFIRM.MER  # Delivery confirmation template
aliasfile:    C:\MERCURY\Mercury\ALIAS.MER    # System-wide alias file
synfile:      C:\MERCURY\Mercury\SYNONYM.MER  # User synonym database
listfile:     C:\MERCURY\Mercury\LISTS.MER    # List of lists
logfile:      C:\MERCURY\Logs\Core\~y-~m-~d.log  # Traffic logging file
# bitnethost:   cunyvm.cuny.edu      # Relay host for ".bitnet" rewrites
poll:         10                   # Seconds between queue polling cycles
scratch:      C:\MERCURY\Scratch   # Where we can write temp files
returnlines:  15                   # How many lines of failed messages to return
postmaster:   Admin   # Local user who acts as postmaster
broadcast:    1                    # Yes, we want broadcast notifications, but
receipts:     0                    # ... no broadcasts for receipt confirmations
PM_notify:    1                    # Do/Don't send errors to the postmaster
change_owner: 1                    # Change message ownership to recipient
# noticeboards: SYS:PUBLIC/NB        # Where to find Pegasus Mail noticeboards
auto_tzone:   1                    # If NZ, obtain timezone information from OS
[MercuryC]
logfile : C:\MERCURY\Logs\MercuryC\~y-~m-~d.log   # Traffic logging file
Session_logging : C:\MERCURY\Sessions\MercuryC\    # Directory for session log files
Session_logmode : 0
host:        gazmend_ram@hotmail.com     # mail mail host which relays for us
scratch:     C:\MERCURY\scratch           # Where we can write temp files
poll:        30                   # Seconds between queue polling cycles
failfile:    C:\MERCURY\Mercury\FAILURE.MER  # Delivery failure template
esmtp:       1                    # Yes, we want to use ESMTP extensions
[MercuryE]
Poll : 15
Timeout : 60
logfile : C:\MERCURY\Logs\MercuryE\~y-~m-~d.log   # Traffic logging file
Session_logging : C:\MERCURY\Sessions\MercuryE\   # Directory for session log files
Session_logmode : 0
# Nameservers : 139.80.64.1
[MercuryD]
Session_logging : C:\MERCURY\Sessions\MercuryD\    # Directory for session log files
Session_logmode : 0
# Timeout : 30
# Poll : 120               # How often to check hosts for new mail (seconds)
[MercuryS]
logfile : C:\MERCURY\Logs\MercuryS\~y-~m-~d.log   # Traffic logging file
Session_logging : C:\MERCURY\Sessions\MercuryS\    # Directory for session log files
Session_logmode : 0
debug:       1                    # Whether or not to show session progress
# allow:       192.156.225.2        # A machine we WILL permit to connect
# refuse:      192.156.225.0        # A group of machines we WON'T permit.
# size:        1500000
Relay : 0         # Control non-local relaying
[MercuryP]
logfile : C:\MERCURY\Logs\MercuryP\~y-~m-~d.log   # Traffic logging file
Session_logging : C:\MERCURY\Sessions\MercuryP\   # Directory for session log files
Session_logmode : 0
Timeout : 60
UIDL_nul_list : 1
New_UIDs : 1
No_NUL_passwords : 1
[MercuryX]
Drain_queues: 1
# Cmd_Delay: 10
# Cmd_Wait: 1
# IE4_Dialling: 0
# Use_ETRN: 1
# Clients_only: 1
# [Groups]
# testgroup            :     TESTGRP
[Domains]
# NetWare Server           Domain name
https://127  :  https://127
https://127  :  https://127.0.0.1
# [Rewrite]
# *                    : pmail.gen.nz
[Maiser]
Maiser               :     Maiser
Helpfile             :     C:\MERCURY\Mercury\MAISER.HLP
Lookupfile           :     C:\MERCURY\Mercury\MAISER.LKP
Send_dir             :     C:\MERCURY\Mercury\SENDABLE
Logfile              :     C:\MERCURY\Logs\Maiser\~y-~m-~d.LOG
Notify               :     C:\MERCURY\Mercury\TMP
Local_only           :     Y
[MercuryH]
logfile : C:\MERCURY\Logs\MercuryH\~y-~m-~d.log   # Traffic logging file
Timeout : 30
[MercuryI]
logfile : C:\MERCURY\Logs\MercuryI\~y-~m-~d.log   # Traffic logging file
Session_logging : C:\MERCURY\Sessions\MercuryI\   # Directory for session log files
Session_logmode : 0
Timeout : 120
Server_Port : 143
Idle_Timeout : 1800
[MercuryB]
logfile : C:\MERCURY\Logs\MercuryB\~y-~m-~d.log   # Traffic logging file
Session_logging : C:\MERCURY\Sessions\MercuryB\   # Directory for session log files
Session_logmode : 0
Timeout : 120
Server_Port : 80
Idle_Timeout : 1800
<p><b>Thnx for your replay!</b> Yes,Mercury is all running!Windows version:Microsoft Windows XP Professional Version 2002 Service Pack2,the path where Mercury is installed is C:\MERCURY and path from XAMPP is C:\xampp.configuration from file MERCURY.INI. is</p><p> </p><p>#  MERCURY.INI generated by Mercury Setup # # #  Sample Bindery Mode / Standalone Mode MERCURY.INI file. #  This sample file implements most of the possible switches for each #  module, but you can edit it to do less if you wish. # #  Anything after a '#' to the end of the line is a comment and #  is stripped out before parsing. Trailing and leading whitespace #  is also stripped before parsing. Many sample commands have been #  left in this file commented out for reference purposes. # #  Note that in general, manual modification of this file is NOT #  RECOMMENDED - use the Mercury "Configuration" menu to change the #  program's settings wherever possible. # [General] myname:      https://127.0.0.1  # Canonical name for this server timezone:    +0000         # Time Zone to add to date fields file_api:    1                    # Use the file api instead of queues mailqueue:   C:\MERCURY\QUEUE   # Where mail should be put for delivery smtpqueue:   C:\MERCURY\QUEUE   # Where the SMTP client should look for mail newmail_path: C:\MERCURY\MAIL\~N [Protocols] C:\MERCURY\mercurys.dll C:\MERCURY\mercuryc.dll C:\MERCURY\mercuryp.dll C:\MERCURY\mercuryd.dll C:\MERCURY\mercuryx.dll C:\MERCURY\mercuryf.dll C:\MERCURY\mercuryh.dll C:\MERCURY\mercuryw.dll C:\MERCURY\mercuryi.dll C:\MERCURY\mercuryb.dll [Mercury] failfile:     C:\MERCURY\Mercury\FAILURE.MER  # Delivery failure notification template confirmfile:  C:\MERCURY\Mercury\CONFIRM.MER  # Delivery confirmation template aliasfile:    C:\MERCURY\Mercury\ALIAS.MER    # System-wide alias file synfile:      C:\MERCURY\Mercury\SYNONYM.MER  # User synonym database listfile:     C:\MERCURY\Mercury\LISTS.MER    # List of lists logfile:      C:\MERCURY\Logs\Core\~y-~m-~d.log  # Traffic logging file # bitnethost:   cunyvm.cuny.edu      # Relay host for ".bitnet" rewrites poll:         10                   # Seconds between queue polling cycles scratch:      C:\MERCURY\Scratch   # Where we can write temp files returnlines:  15                   # How many lines of failed messages to return postmaster:   Admin   # Local user who acts as postmaster broadcast:    1                    # Yes, we want broadcast notifications, but receipts:     0                    # ... no broadcasts for receipt confirmations PM_notify:    1                    # Do/Don't send errors to the postmaster change_owner: 1                    # Change message ownership to recipient # noticeboards: SYS:PUBLIC/NB        # Where to find Pegasus Mail noticeboards auto_tzone:   1                    # If NZ, obtain timezone information from OS [MercuryC] logfile : C:\MERCURY\Logs\MercuryC\~y-~m-~d.log   # Traffic logging file Session_logging : C:\MERCURY\Sessions\MercuryC\    # Directory for session log files Session_logmode : 0 host:        gazmend_ram@hotmail.com     # mail mail host which relays for us scratch:     C:\MERCURY\scratch           # Where we can write temp files poll:        30                   # Seconds between queue polling cycles returnlines: 15                   # How many lines of failed messages to return failfile:    C:\MERCURY\Mercury\FAILURE.MER  # Delivery failure template esmtp:       1                    # Yes, we want to use ESMTP extensions [MercuryE] Poll : 15 Timeout : 60 logfile : C:\MERCURY\Logs\MercuryE\~y-~m-~d.log   # Traffic logging file Session_logging : C:\MERCURY\Sessions\MercuryE\   # Directory for session log files Session_logmode : 0 # Nameservers : 139.80.64.1 [MercuryD] Session_logging : C:\MERCURY\Sessions\MercuryD\    # Directory for session log files Session_logmode : 0 Scratch : C:\MERCURY\Scratch\MercuryD # Timeout : 30 # Poll : 120               # How often to check hosts for new mail (seconds) [MercuryS] logfile : C:\MERCURY\Logs\MercuryS\~y-~m-~d.log   # Traffic logging file Session_logging : C:\MERCURY\Sessions\MercuryS\    # Directory for session log files Session_logmode : 0 debug:       1                    # Whether or not to show session progress # allow:       192.156.225.2        # A machine we WILL permit to connect # refuse:      192.156.225.0        # A group of machines we WON'T permit. # size:        1500000 Relay : 0         # Control non-local relaying [MercuryP] logfile : C:\MERCURY\Logs\MercuryP\~y-~m-~d.log   # Traffic logging file Session_logging : C:\MERCURY\Sessions\MercuryP\   # Directory for session log files Session_logmode : 0 Scratch : C:\MERCURY\Scratch\MercuryP Timeout : 60 UIDL_nul_list : 1 New_UIDs : 1 No_NUL_passwords : 1 [MercuryX] Drain_queues: 1 # Cmd_Delay: 10 # Cmd_Wait: 1 # IE4_Dialling: 0 # Use_ETRN: 1 # Clients_only: 1 # Sunday: 0800,1800,3,15,30,60 # Monday: 0830,2100,5,15,60,60 # Tuesday: 0830,2100,5,15,60,60 # Wednesday: 1500,1900,2,30,5,30 # Thursday: 0900,1900,2,30,0,0 # Friday: 0830,2100,5,15,60,60 # Saturday: 1031,1035,2,45,-1,0 # [Groups] # testgroup            :     TESTGRP [Domains] # NetWare Server           Domain name https://127  :  https://127 https://127  :  https://127.0.0.1 # [Rewrite] # *                    : pmail.gen.nz [Maiser] Maiser               :     Maiser Helpfile             :     C:\MERCURY\Mercury\MAISER.HLP Lookupfile           :     C:\MERCURY\Mercury\MAISER.LKP Send_dir             :     C:\MERCURY\Mercury\SENDABLE Logfile              :     C:\MERCURY\Logs\Maiser\~y-~m-~d.LOG Notify               :     C:\MERCURY\Mercury\TMP Local_only           :     Y [MercuryH] logfile : C:\MERCURY\Logs\MercuryH\~y-~m-~d.log   # Traffic logging file # Addressbook : \\CLIO\SYS\SYSTEM\MERCURY\PH.PMR # MOTD : \\CLIO\SYS\SYSTEM\MERCURY\PH-MOTD.TXT # Administrator : postmaster@clio.pmail.gen.nz Timeout : 30 [MercuryI] Scratch : C:\MERCURY\Scratch\MercuryI logfile : C:\MERCURY\Logs\MercuryI\~y-~m-~d.log   # Traffic logging file Session_logging : C:\MERCURY\Sessions\MercuryI\   # Directory for session log files Session_logmode : 0 Timeout : 120 Server_Port : 143 Idle_Timeout : 1800 [MercuryB] Scratch : C:\MERCURY\Scratch\MercuryB logfile : C:\MERCURY\Logs\MercuryB\~y-~m-~d.log   # Traffic logging file Session_logging : C:\MERCURY\Sessions\MercuryB\   # Directory for session log files Session_logmode : 0 Timeout : 120 Server_Port : 80 Idle_Timeout : 1800 # URL_Base : enter_your_domain_here  </p>
Some things to fix:
[General]
That's not a host name! Call it "myserver" or whatever.
[Protocols]
This is technically OK but do you really need all these modules? If you aren't running the current release (v. 4.74) you should definitely switch off MercuryX.
[MercuryC]
Session_logmode : 0
Not a relay host (it's a Hotmail email address).
[Domains]
This is very broken. HTTP and HTTPS are web server protocols. Change it in Core configuration / Local domains. A standard domain configuration looks something like this:
calliope calliope
calliope calliope.pmail.gen.nz
calliope [192.156.225.76]
Have a look in Mercury help or the manual for more information!
<div>Some things to fix:</div><div> </div><blockquote><div><i>[General]</i></div><div><i>myname:      https://127.0.0.1  # Canonical name for this server</i></div></blockquote><div> </div><div>That's not a host name! Call it "myserver" or whatever.</div><div> </div><blockquote><div><i>[Protocols]</i></div><div><i>C:\MERCURY\mercurys.dll</i></div><div><i>C:\MERCURY\mercuryc.dll</i></div><div><i>C:\MERCURY\mercuryp.dll</i></div><div><i>C:\MERCURY\mercuryd.dll</i></div><div><i>C:\MERCURY\mercuryx.dll</i></div><div><i>C:\MERCURY\mercuryf.dll</i></div><div><i>C:\MERCURY\mercuryh.dll</i></div><div><i>C:\MERCURY\mercuryw.dll</i></div><div><i>C:\MERCURY\mercuryi.dll</i></div><div><i>C:\MERCURY\mercuryb.dll</i></div></blockquote><div> </div><div>This is technically OK but do you really need all these modules? If you aren't running the current release (v. 4.74) you should definitely switch off MercuryX.</div><div> </div><blockquote><div><i>[MercuryC]</i></div><div><i>logfile : C:\MERCURY\Logs\MercuryC\~y-~m-~d.log   # Traffic logging file</i></div><div><i>Session_logging : C:\MERCURY\Sessions\MercuryC\    # Directory for session log files</i></div><div><i>Session_logmode : 0</i></div><div><i>host:        gazmend_ram@hotmail.com     # mail mail host which relays for us</i></div></blockquote><div> </div><div>Not a relay host (it's a Hotmail email address). </div><blockquote><div> </div><div><i>[Domains]</i></div><div><i># NetWare Server           Domain name</i></div><div><i>https://127  :  https://127</i></div><div><i>https://127  :  https://127.0.0.1</i></div></blockquote><div> </div><div>This is very broken. HTTP and HTTPS are web server protocols. Change it in Core configuration / Local domains. A standard domain configuration looks something like this:</div><div><span class="Apple-tab-span" style="white-space: pre;"> </span>calliope<span class="Apple-tab-span" style="white-space: pre;"> </span>calliope</div><div><span class="Apple-tab-span" style="white-space: pre;"> </span>calliope<span class="Apple-tab-span" style="white-space: pre;"> </span>calliope.pmail.gen.nz</div><div><span class="Apple-tab-span" style="white-space: pre;"> </span>calliope<span class="Apple-tab-span" style="white-space: pre;"> </span>[192.156.225.76] </div><div> </div><div>Have a look in Mercury help or the manual for more information!</div><div> </div><div>/Rolf </div><div> </div>
I have read this articel http://tobias-seckinger.de/2011/08/mercury-unter-xampp-konfigurieren/ and I have done the same!
in the MERCURY.INI file
#  Sample Bindery Mode MERCURY.INI file (in fact, the one I use on
#  my production server). This one implements most of the possible
#  switches for each module, but you can edit it to do less if you
#  wish. All the fields shown below are described in the file
#  MGUIDE.HLP which is supplied in the Mercury archive.
[General]
myname:          localhost    # Canonical name for this server
mailqueue:       C:\XAMPP\MERCURYMAIL\QUEUE    # Where mail should be put for delivery
smtpqueue:       C:\XAMPP\MERCURYMAIL\QUEUE    # Where the SMTP client should look for mail
newmail_path:    C:\XAMPP\MERCURYMAIL\MAIL\~N    # Where to find the users' WinPMail mailboxes.
[Protocols]
C:\xampp\MERCURYMAIL\mercurys.dll
C:\xampp\MERCURYMAIL\mercurye.dll
C:\xampp\MERCURYMAIL\mercuryp.dll
C:\xampp\MERCURYMAIL\mercuryd.dll
C:\xampp\MERCURYMAIL\mercuryx.dll
C:\xampp\MERCURYMAIL\mercuryf.dll
C:\xampp\MERCURYMAIL\mercuryh.dll
C:\xampp\MERCURYMAIL\mercuryw.dll
C:\xampp\MERCURYMAIL\mercuryi.dll
C:\xampp\MERCURYMAIL\mercuryb.dll
[Mercury]
failfile:      C:\xampp\MERCURYMAIL\Mercury\FAILURE.MER    # Delivery failure notification template
confirmfile:   C:\xampp\MERCURYMAIL\Mercury\CONFIRM.MER    # Delivery confirmation template
aliasfile:     C:\xampp\MERCURYMAIL\Mercury\ALIAS.MER    # System-wide alias file
synfile:       C:\xampp\MERCURYMAIL\Mercury\SYNONYM.MER    # User synonym database
listfile:      C:\xampp\MERCURYMAIL\Mercury\LISTS.MER    # List of lists
logwidth:      30    # Width of address fields in logfile
retpath:       1    # Do/Don't use 'return-path' for errors
maxhops:       30    # Used to detect mailing loops
gullible:      0    # If NZ, don't validate 'From' fields
bitnethost:    cunyvm.cuny.edu    # Relay host for '.bitnet' rewrites
scratch:       C:\xampp\MERCURYMAIL\Scratch    # Where we can write temp files
postmaster:    Admin    # NetWare UIC of postmaster
LogLevel:      15    # System message reporting level
LogMax:        100    # Maximum number of system messages to store
RetryPeriod:   30    # Period between job retries (minutes)
MaxRetries:    16    # Maximum number of times a job can fail
TwoPasses:     1    # If NZ, process submission queue in 2 passes
Autoaddress:   0    # If NZ, auto-generate user addresses based on name
Daily_exit:    0    # If NZ, auto-restart each day after maintenance
No_Areply:     0    # If NZ, disable automatic replies system-wide
Alt_Forward:   0    # If NZ, allow alternate forwarding specification
Maint_hour:    2    # Hour for daily maintenance (24-hour clock)
Maint_min:     0    # Minute for daily maintenance
Retry_Mode:    0    # If NZ, use progressive backoff for queue retries
Local_DSNs:    1    # If NZ generate Delivery Status for local users only
DSN_time1:     10800    # Seconds deferred before first DSN is sent
DSN_time2:     86400    # Seconds deferred before second DSN is sent
DSN_time3:     259200    # Seconds deferred before third DSN is sent
Host_in_title: 0    # If NZ, show hostname in system tray and taskbar
Lingering:     0    # Enable or disable 'lingering mailboxes'
Linger_Timeout: 60   # Seconds before a lingering mailbox is shut down
Alert_Host:    notify.pmail.com    # Host to check for licensee advisories
Alert_Interval: 720   # Frequency in minutes (min 240) for checks
Alert_Flags:   3    # Flags controlling advisory checks
[MercuryC]
# Session_logging:  G:\           # Directory to write session transcripts
host:             # mail mail host which relays for us
scratch:     C:\xampp\MERCURYMAIL\Mercury   # Where we can write temp files
failfile:    C:\xampp\MERCURYMAIL\Mercury\FAILURE.MER  # Delivery failure template
[MercuryE]
Poll : 15
Timeout : 60
# Session_logging : o:\mail\mercury\melogs
# Session_logmode : 1
[MercuryD]
scratch              :     C:\xampp\MERCURYMAIL\Mercury
# Timeout : 30
[MercuryS]
Debug : 1
HELO : CS SMTP
Logfile : C:\xampp\MERCURYMAIL\Logs\MERCURYS.LOG
Timeout : 30
Relay : 0
Strict_Relay : 0
Interface : 127.0.0.1
Allow_Illegals : 0
SMTP_Authentication : 0
Compliance_Settings : 0
Maximum_Failed_Rcpts : 4
Max_Relay_Attempts : 4
SSL_Mode : 0
ST_Blacklisting : 288
No_VRFY : 0
SMTP_ConnFlags : 0
[MercuryP]
Scratch : C:\xampp\MERCURYMAIL\Mercury
Stack : 32768
Mark_Read : 1
SSL_Mode : 0
Login_Disabled : 0
UIDL_nul_list : 1
New_UIDs : 0
Timeout : 60
[MercuryX]
# Cmd_Delay: 10
# Cmd_Wait: 1
# IE4_Dialling: 0
# Use_ETRN: 1
# Clients_only: 1
# [Groups]
[Domains]
localhost: localhost
localhost: localhost.net
localhost: localhost.org
localhost: localhost.com
[Maiser]
Helpfile:        C:\xampp\MERCURYMAIL\Mercury\MAISER.HLP   # Help sent on failed maiser requests
Lookupfile:      C:\xampp\MERCURYMAIL\Mercury\MAISER.LKP   # Format file for the 'lookup' command
Send_dir:        C:\xampp\MERCURYMAIL\Mercury\SENDABLE   # Directory for the 'send' command
Logfile:         C:\xampp\MERCURYMAIL\Logs\MAISER.LOG   # Mail server log file
Notify:          C:\xampp\MERCURYMAIL\Mercury\TMP   # Dir. for pending 'notify' commands
[MercuryH]
Logfile              :     C:\xampp\MERCURYMAIL\Logs\MERCURYH.LOG
Timeout : 30
[MercuryI]
Scratch : C:\xampp\MERCURYMAIL\SCRATCH
Timeout : 120
Server_Port : 143
Idle_Timeout : 1800
SSL_Mode : 0
Login_Disabled : 0
[MercuryB]
# Logfile : o:\mail\tmp\mercuryb.log
Timeout : 120
Server_Port : 2224
# Session_logging : o:\mail\mercury\mblogs
# Session_logmode : 0
Idle_Timeout : 1800
[Groups]
[Rewrite]
[Statistics]
StatFlags:    0  # Statistical reporting settings
STF_Hours:    24  # How often to write stat log files
STM_Hours:    24  # How often to e-mail stat log files
at the admins page http://localhost/joomla/administrator/index.php?option=com_messages
Private Messages Manager: Messages
Strict Standards: call_user_func_array() expects parameter 1 to
be a valid callback, non-static method JHtmlMessages::state() should not
be called statically in C:\xampp\htdocs\joomla\libraries\joomla\html\html.php on line 222
Read
 in the Mozilla Thunderbird wenn the user get emails from admin
Please log in to http://localhost/joomla/administrator/index.php?option=com_messages&view=message&message_id=30 to read your message.
 when I click the link
500 - An error has occurred.
You are not authorised to view this resource.
Return to Control Panel
Finally I Hope you understand my probelm!
<p>I have read this articel http://tobias-seckinger.de/2011/08/mercury-unter-xampp-konfigurieren/ and I have done the same!</p><p>in the MERCURY.INI file </p><p>#  MERCURY.INI generated by Mercury Setup # # #  Sample Bindery Mode MERCURY.INI file (in fact, the one I use on #  my production server). This one implements most of the possible #  switches for each module, but you can edit it to do less if you #  wish. All the fields shown below are described in the file #  MGUIDE.HLP which is supplied in the Mercury archive. # #  Anything after a '#' to the end of the line is a comment and #  is stripped out before parsing. Trailing and leading whitespace #  is also stripped before parsing. Many sample commands have been #  left in this file commented out for reference purposes. # [General] myname:          localhost    # Canonical name for this server timezone:        +0000    # Time Zone to add to date fields file_api:        1    # Use the file api instead of queues mailqueue:       C:\XAMPP\MERCURYMAIL\QUEUE    # Where mail should be put for delivery smtpqueue:       C:\XAMPP\MERCURYMAIL\QUEUE    # Where the SMTP client should look for mail newmail_path:    C:\XAMPP\MERCURYMAIL\MAIL\~N    # Where to find the users' WinPMail mailboxes. [Protocols] C:\xampp\MERCURYMAIL\mercurys.dll C:\xampp\MERCURYMAIL\mercurye.dll C:\xampp\MERCURYMAIL\mercuryp.dll C:\xampp\MERCURYMAIL\mercuryd.dll C:\xampp\MERCURYMAIL\mercuryx.dll C:\xampp\MERCURYMAIL\mercuryf.dll C:\xampp\MERCURYMAIL\mercuryh.dll C:\xampp\MERCURYMAIL\mercuryw.dll C:\xampp\MERCURYMAIL\mercuryi.dll C:\xampp\MERCURYMAIL\mercuryb.dll [Mercury] failfile:      C:\xampp\MERCURYMAIL\Mercury\FAILURE.MER    # Delivery failure notification template confirmfile:   C:\xampp\MERCURYMAIL\Mercury\CONFIRM.MER    # Delivery confirmation template aliasfile:     C:\xampp\MERCURYMAIL\Mercury\ALIAS.MER    # System-wide alias file synfile:       C:\xampp\MERCURYMAIL\Mercury\SYNONYM.MER    # User synonym database listfile:      C:\xampp\MERCURYMAIL\Mercury\LISTS.MER    # List of lists logwidth:      30    # Width of address fields in logfile retpath:       1    # Do/Don't use 'return-path' for errors maxhops:       30    # Used to detect mailing loops gullible:      0    # If NZ, don't validate 'From' fields bitnethost:    cunyvm.cuny.edu    # Relay host for '.bitnet' rewrites poll:          10   # Seconds between queue polling cycles scratch:       C:\xampp\MERCURYMAIL\Scratch    # Where we can write temp files returnlines:   15    # How many lines of failed messages to return postmaster:    Admin    # NetWare UIC of postmaster broadcast:     1    # Yes, we want broadcast notifications, but receipts:      0    # ... no broadcasts for receipt confirmations PM_notify:     1    # Do/Don't send errors to the postmaster change_owner:  1    # Change message ownership to recipient auto_tzone:    1    # If NZ, obtain timezone information from OS LogLevel:      15    # System message reporting level LogMax:        100    # Maximum number of system messages to store RetryPeriod:   30    # Period between job retries (minutes) MaxRetries:    16    # Maximum number of times a job can fail TwoPasses:     1    # If NZ, process submission queue in 2 passes Autoaddress:   0    # If NZ, auto-generate user addresses based on name Daily_exit:    0    # If NZ, auto-restart each day after maintenance No_Areply:     0    # If NZ, disable automatic replies system-wide Alt_Forward:   0    # If NZ, allow alternate forwarding specification Maint_hour:    2    # Hour for daily maintenance (24-hour clock) Maint_min:     0    # Minute for daily maintenance Retry_Mode:    0    # If NZ, use progressive backoff for queue retries Local_DSNs:    1    # If NZ generate Delivery Status for local users only DSN_time1:     10800    # Seconds deferred before first DSN is sent DSN_time2:     86400    # Seconds deferred before second DSN is sent DSN_time3:     259200    # Seconds deferred before third DSN is sent Host_in_title: 0    # If NZ, show hostname in system tray and taskbar Lingering:     0    # Enable or disable 'lingering mailboxes' Linger_Timeout: 60   # Seconds before a lingering mailbox is shut down Alert_Host:    notify.pmail.com    # Host to check for licensee advisories Alert_Interval: 720   # Frequency in minutes (min 240) for checks Alert_Flags:   3    # Flags controlling advisory checks [MercuryC] # Session_logging:  G:\           # Directory to write session transcripts host:             # mail mail host which relays for us scratch:     C:\xampp\MERCURYMAIL\Mercury   # Where we can write temp files poll:        30                   # Seconds between queue polling cycles returnlines: 15                   # How many lines of failed messages to return failfile:    C:\xampp\MERCURYMAIL\Mercury\FAILURE.MER  # Delivery failure template esmtp:       1                    # Yes, we want to use ESMTP extensions [MercuryE] Poll : 15 Timeout : 60 # Session_logging : o:\mail\mercury\melogs # Session_logmode : 1 # Nameservers : 139.80.64.1 [MercuryD] scratch              :     C:\xampp\MERCURYMAIL\Mercury # Timeout : 30 # Poll : 120               # How often to check hosts for new mail (seconds) [MercuryS] Debug : 1 HELO : CS SMTP Logfile : C:\xampp\MERCURYMAIL\Logs\MERCURYS.LOG Timeout : 30 Relay : 0 Strict_Relay : 0 Interface : 127.0.0.1 Allow_Illegals : 0 SMTP_Authentication : 0 Compliance_Settings : 0 Maximum_Failed_Rcpts : 4 Max_Relay_Attempts : 4 SSL_Mode : 0 ST_Blacklisting : 288 No_VRFY : 0 SMTP_ConnFlags : 0 [MercuryP] Scratch : C:\xampp\MERCURYMAIL\Mercury Stack : 32768 Interface : 127.0.0.1 Mark_Read : 1 SSL_Mode : 0 Login_Disabled : 0 UIDL_nul_list : 1 New_UIDs : 0 No_NUL_passwords : 1 Timeout : 60 [MercuryX] # Cmd_Delay: 10 # Cmd_Wait: 1 # IE4_Dialling: 0 # Use_ETRN: 1 # Clients_only: 1 # Sunday: 0800,1800,3,15,30,60 # Monday: 0830,2100,5,15,60,60 # Tuesday: 0830,2100,5,15,60,60 # Wednesday: 1500,1900,2,30,5,30 # Thursday: 0900,1900,2,30,0,0 # Friday: 0830,2100,5,15,60,60 # Saturday: 1031,1035,2,45,-1,0 # [Groups] # testgroup            :     TESTGRP [Domains] localhost: localhost localhost: localhost.net localhost: localhost.org localhost: localhost.com [Maiser] Maiser:          Maiser   # 'Username' of mail server account Helpfile:        C:\xampp\MERCURYMAIL\Mercury\MAISER.HLP   # Help sent on failed maiser requests Lookupfile:      C:\xampp\MERCURYMAIL\Mercury\MAISER.LKP   # Format file for the 'lookup' command Send_dir:        C:\xampp\MERCURYMAIL\Mercury\SENDABLE   # Directory for the 'send' command Logfile:         C:\xampp\MERCURYMAIL\Logs\MAISER.LOG   # Mail server log file Notify:          C:\xampp\MERCURYMAIL\Mercury\TMP   # Dir. for pending 'notify' commands NoList:          N   # If 'Y', disable the 'list' command Local_only:      Y   # If 'Y', local 'notify' commands only [MercuryH] Logfile              :     C:\xampp\MERCURYMAIL\Logs\MERCURYH.LOG # Addressbook : \\CLIO\SYS\SYSTEM\MERCURY\PH.PMR # MOTD : \\CLIO\SYS\SYSTEM\MERCURY\PH-MOTD.TXT # Administrator : postmaster@clio.pmail.gen.nz Timeout : 30 [MercuryI] Scratch : C:\xampp\MERCURYMAIL\SCRATCH Timeout : 120 Server_Port : 143 Idle_Timeout : 1800 SSL_Mode : 0 Login_Disabled : 0 [MercuryB] Scratch : C:\xampp\MERCURYMAIL\SCRATCH # Logfile : o:\mail\tmp\mercuryb.log Timeout : 120 Server_Port : 2224 # Session_logging : o:\mail\mercury\mblogs # Session_logmode : 0 Idle_Timeout : 1800 # URL_Base : enter_your_domain_here [Groups] [Rewrite] [Statistics] StatFlags:    0  # Statistical reporting settings STF_Hours:    24  # How often to write stat log files STM_Hours:    24  # How often to e-mail stat log files at the admins page <b>http://localhost/joomla/administrator/index.php?option=com_messages</b></p><h2>Private Messages Manager: Messages</h2><p> <b>Strict Standards</b>: call_user_func_array() expects parameter 1 to be a valid callback, non-static method JHtmlMessages::state() should not be called statically in <b>C:\xampp\htdocs\joomla\libraries\joomla\html\html.php</b> on line <b>222</b> <a href="http://localhost/joomla/administrator/index.php?option=com_messages#" title="Mark as Unread"><img src="http://localhost/joomla/administrator/templates/bluestork/images/admin/tick.png" alt="Read"></a> </p><p> in the Mozilla Thunderbird wenn the user get emails from admin </p><pre wrap="">Please log in to <a href="http://localhost/joomla/administrator/index.php?option=com_messages&view=message&message_id=30" class="moz-txt-link-freetext">http://localhost/joomla/administrator/index.php?option=com_messages&view=message&message_id=30</a> to read your message. </pre><pre wrap=""> when I click the link</pre><pre wrap=""> </pre><h1>500 - An error has occurred.</h1> <p>You are not authorised to view this resource.</p> <p><a href="http://localhost/joomla/administrator/index.php">Return to Control Panel</a></p><p> </p><p>Finally I Hope you understand my probelm! </p><pre wrap=""> </pre>
Please start by verifying if Mercury is installed in C:\MERCURY\ or C:\xampp\MERCURYMAIL\. It should be either, not both, and you need to know which.
You can perhaps use Mr. Seckinger's guide to help you set up a mail server for local use. If it however fails we are happy to give you advise on how to configure Mercury here, but specific questions regarding Mr. Seckinger's configuration example should probably be answered by him.
The address to the Joomla community site is http://forum.joomla.org/.
<p>Please start by verifying if Mercury is installed in C:\MERCURY\ or C:\xampp\MERCURYMAIL\. It should be either, not both, and you need to know which.</p><p>You can perhaps use Mr. S<font face="Tahoma, Arial, Helvetica">eckinger's guide to help you set up a mail server for local use. If it however fails we are happy to give you advise on how to configure Mercury here, but specific questions regarding </font>Mr. S<font face="Tahoma, Arial, Helvetica">eckinger's configuration example should probably be answered by him.</font></p><p>The address to the Joomla community site is <a href="http://forum.joomla.org/">http://forum.joomla.org/</a>.</p><p>/Rolf</p>
The MercuryMail is in C:\xampp\MercuryMail installed. where I can find Mr. Seckinger's guide??
<p>Hi,</p><p>The MercuryMail is in C:\xampp\MercuryMail installed. where I can find Mr. S<font face="Tahoma, Arial, Helvetica">eckinger's guide??</font><font face="Tahoma, Arial, Helvetica"> </font></p>
[quote user="gazi"]The MercuryMail is in C:\xampp\MercuryMail installed. where I can find Mr. Seckinger's guide?? [/quote]
I would not recommend the guide that you linked to.  Configuring an email server can be complex. The guide is far too simple, lacks explanation, and may expose the server on the internet to being hijacked as an open relay.
Use the help that Rolf suggests.
<P>[quote user="gazi"]The MercuryMail is in C:\xampp\MercuryMail installed. where I can find Mr. S<FONT face="Tahoma, Arial, Helvetica">eckinger's guide??</FONT><FONT face="Tahoma, Arial, Helvetica"> </FONT>[/quote]</P> <P>I would not recommend the guide that you linked to.  Configuring an email server can be complex. The guide is far too simple, lacks explanation, and may expose the server on the internet to being hijacked as an open relay.</P> <P>Use the help that Rolf suggests.</P>
