PaulW - Four years ago I was playing with XAMPP and at that time it was not intended for use in a production environment.
I switched to new Mercury and have problems with the mailing system.As far as I have:
Installed XAMPP (Apache, MySQL and Mercury run),everything on my PC that I want to use as a server.Then I got my fixed IP assigned to the domain.Until now everything was OK.
But now ... I try on my side http://localhost/joomla/administrator/ to send email to admin(Super Admin) and the admin could not get email from Users in another side the users can't get emails from admin
Mailer: SMTP Server
Mail-From: admin@localhost.com
sendmail-path: /usr/sbin/sendmail
auth: no
SMTP-User: (leer)
SMTP-Pass: (leer)
SMTP-Host: localhost!
My question specifically:
Do I have something set up at Mercury?How is it stored my email?I did not have much experience with email servers, ne still fail the message I got: Could not instantiate mail functio
please help
Is Mercury at all running? If so you can get a lot of information from console windows and from log files. If you want us to help you will need to provide information about the environment (Windows version, path where Mercury is installed), and preferably post the contents of the configuration file MERCURY.INI.
There is a lot of information in the built-in help system, and I recommend reading relevant parts of the PDF manual (man-473.pdf in the Mercury directory).
Thnx for your replay! Yes,Mercury is all running!Windows version:Microsoft Windows XP Professional Version 2002 Service Pack2,the path where Mercury is installed is C:\MERCURY and path from XAMPP is C:\xampp.configuration from file MERCURY.INI. is
# MERCURY.INI generated by Mercury Setup
# Sample Bindery Mode / Standalone Mode MERCURY.INI file.
# This sample file implements most of the possible switches for each
# module, but you can edit it to do less if you wish.
# Anything after a '#' to the end of the line is a comment and
# is stripped out before parsing. Trailing and leading whitespace
# is also stripped before parsing. Many sample commands have been
# left in this file commented out for reference purposes.
# Note that in general, manual modification of this file is NOT
# RECOMMENDED - use the Mercury "Configuration" menu to change the
# program's settings wherever possible.
[General]
myname: https://127.0.0.1 # Canonical name for this server
timezone: +0000 # Time Zone to add to date fields
mailqueue: C:\MERCURY\QUEUE # Where mail should be put for delivery
smtpqueue: C:\MERCURY\QUEUE # Where the SMTP client should look for mail
newmail_path: C:\MERCURY\MAIL\~N
[Protocols]
C:\MERCURY\mercurys.dll
C:\MERCURY\mercuryc.dll
C:\MERCURY\mercuryp.dll
C:\MERCURY\mercuryd.dll
C:\MERCURY\mercuryx.dll
C:\MERCURY\mercuryf.dll
C:\MERCURY\mercuryh.dll
C:\MERCURY\mercuryw.dll
C:\MERCURY\mercuryi.dll
C:\MERCURY\mercuryb.dll
[Mercury]
failfile: C:\MERCURY\Mercury\FAILURE.MER # Delivery failure notification template
confirmfile: C:\MERCURY\Mercury\CONFIRM.MER # Delivery confirmation template
aliasfile: C:\MERCURY\Mercury\ALIAS.MER # System-wide alias file
synfile: C:\MERCURY\Mercury\SYNONYM.MER # User synonym database
listfile: C:\MERCURY\Mercury\LISTS.MER # List of lists
logfile: C:\MERCURY\Logs\Core\~y-~m-~d.log # Traffic logging file
# bitnethost: cunyvm.cuny.edu # Relay host for ".bitnet" rewrites
poll: 10 # Seconds between queue polling cycles
scratch: C:\MERCURY\Scratch # Where we can write temp files
postmaster: Admin # Local user who acts as postmaster
broadcast: 1 # Yes, we want broadcast notifications, but
PM_notify: 1 # Do/Don't send errors to the postmaster
change_owner: 1 # Change message ownership to recipient
# noticeboards: SYS:PUBLIC/NB # Where to find Pegasus Mail noticeboards
[MercuryC]
logfile : C:\MERCURY\Logs\MercuryC\~y-~m-~d.log # Traffic logging file
Session_logging : C:\MERCURY\Sessions\MercuryC\ # Directory for session log files
Session_logmode : 0
host: gazmend_ram@hotmail.com # mail mail host which relays for us
scratch: C:\MERCURY\scratch # Where we can write temp files
poll: 30 # Seconds between queue polling cycles
failfile: C:\MERCURY\Mercury\FAILURE.MER # Delivery failure template
esmtp: 1 # Yes, we want to use ESMTP extensions
[MercuryE]
Poll : 15
Timeout : 60
logfile : C:\MERCURY\Logs\MercuryE\~y-~m-~d.log # Traffic logging file
Session_logging : C:\MERCURY\Sessions\MercuryE\ # Directory for session log files
Session_logmode : 0
# Nameservers : 139.80.64.1
[MercuryD]
Session_logging : C:\MERCURY\Sessions\MercuryD\ # Directory for session log files
Session_logmode : 0
# Timeout : 30
# Poll : 120 # How often to check hosts for new mail (seconds)
[MercuryS]
logfile : C:\MERCURY\Logs\MercuryS\~y-~m-~d.log # Traffic logging file
Session_logging : C:\MERCURY\Sessions\MercuryS\ # Directory for session log files
Session_logmode : 0
debug: 1 # Whether or not to show session progress
# allow: 192.156.225.2 # A machine we WILL permit to connect
# refuse: 192.156.225.0 # A group of machines we WON'T permit.
# size: 1500000
Relay : 0 # Control non-local relaying
[MercuryP]
logfile : C:\MERCURY\Logs\MercuryP\~y-~m-~d.log # Traffic logging file
Session_logging : C:\MERCURY\Sessions\MercuryP\ # Directory for session log files
Session_logmode : 0
Timeout : 60
UIDL_nul_list : 1
New_UIDs : 1
No_NUL_passwords : 1
[MercuryX]
Drain_queues: 1
# Cmd_Delay: 10
# Cmd_Wait: 1
# IE4_Dialling: 0
# Use_ETRN: 1
# Clients_only: 1
# [Groups]
# testgroup : TESTGRP
[Domains]
# NetWare Server Domain name
https://127 : https://127
https://127 : https://127.0.0.1
# [Rewrite]
# * : pmail.gen.nz
[Maiser]
Maiser : Maiser
Helpfile : C:\MERCURY\Mercury\MAISER.HLP
Lookupfile : C:\MERCURY\Mercury\MAISER.LKP
Send_dir : C:\MERCURY\Mercury\SENDABLE
Logfile : C:\MERCURY\Logs\Maiser\~y-~m-~d.LOG
Notify : C:\MERCURY\Mercury\TMP
Local_only : Y
[MercuryH]
logfile : C:\MERCURY\Logs\MercuryH\~y-~m-~d.log # Traffic logging file
Timeout : 30
[MercuryI]
logfile : C:\MERCURY\Logs\MercuryI\~y-~m-~d.log # Traffic logging file
Session_logging : C:\MERCURY\Sessions\MercuryI\ # Directory for session log files
Session_logmode : 0
Timeout : 120
Server_Port : 143
Idle_Timeout : 1800
[MercuryB]
logfile : C:\MERCURY\Logs\MercuryB\~y-~m-~d.log # Traffic logging file
Session_logging : C:\MERCURY\Sessions\MercuryB\ # Directory for session log files
Session_logmode : 0
Timeout : 120
Server_Port : 80
Idle_Timeout : 1800
[General]myname: https://127.0.0.1 # Canonical name for this server
[Protocols]C:\MERCURY\mercurys.dllC:\MERCURY\mercuryc.dllC:\MERCURY\mercuryp.dllC:\MERCURY\mercuryd.dllC:\MERCURY\mercuryx.dllC:\MERCURY\mercuryf.dllC:\MERCURY\mercuryh.dllC:\MERCURY\mercuryw.dllC:\MERCURY\mercuryi.dllC:\MERCURY\mercuryb.dll
[MercuryC]logfile : C:\MERCURY\Logs\MercuryC\~y-~m-~d.log # Traffic logging fileSession_logging : C:\MERCURY\Sessions\MercuryC\ # Directory for session log filesSession_logmode : 0host: gazmend_ram@hotmail.com # mail mail host which relays for us
[Domains]# NetWare Server Domain namehttps://127 : https://127https://127 : https://127.0.0.1
I have read this articel http://tobias-seckinger.de/2011/08/mercury-unter-xampp-konfigurieren/ and I have done the same!
in the MERCURY.INI file
# Sample Bindery Mode MERCURY.INI file (in fact, the one I use on
# my production server). This one implements most of the possible
# switches for each module, but you can edit it to do less if you
# wish. All the fields shown below are described in the file
# MGUIDE.HLP which is supplied in the Mercury archive.
[General]
myname: localhost # Canonical name for this server
mailqueue: C:\XAMPP\MERCURYMAIL\QUEUE # Where mail should be put for delivery
smtpqueue: C:\XAMPP\MERCURYMAIL\QUEUE # Where the SMTP client should look for mail
newmail_path: C:\XAMPP\MERCURYMAIL\MAIL\~N # Where to find the users' WinPMail mailboxes.
[Protocols]
C:\xampp\MERCURYMAIL\mercurys.dll
C:\xampp\MERCURYMAIL\mercurye.dll
C:\xampp\MERCURYMAIL\mercuryp.dll
C:\xampp\MERCURYMAIL\mercuryd.dll
C:\xampp\MERCURYMAIL\mercuryx.dll
C:\xampp\MERCURYMAIL\mercuryf.dll
C:\xampp\MERCURYMAIL\mercuryh.dll
C:\xampp\MERCURYMAIL\mercuryw.dll
C:\xampp\MERCURYMAIL\mercuryi.dll
C:\xampp\MERCURYMAIL\mercuryb.dll
[Mercury]
failfile: C:\xampp\MERCURYMAIL\Mercury\FAILURE.MER # Delivery failure notification template
confirmfile: C:\xampp\MERCURYMAIL\Mercury\CONFIRM.MER # Delivery confirmation template
aliasfile: C:\xampp\MERCURYMAIL\Mercury\ALIAS.MER # System-wide alias file
synfile: C:\xampp\MERCURYMAIL\Mercury\SYNONYM.MER # User synonym database
listfile: C:\xampp\MERCURYMAIL\Mercury\LISTS.MER # List of lists
retpath: 1 # Do/Don't use 'return-path' for errors
bitnethost: cunyvm.cuny.edu # Relay host for '.bitnet' rewrites
scratch: C:\xampp\MERCURYMAIL\Scratch # Where we can write temp files
postmaster: Admin # NetWare UIC of postmaster
RetryPeriod: 30 # Period between job retries (minutes)
MaxRetries: 16 # Maximum number of times a job can fail
TwoPasses: 1 # If NZ, process submission queue in 2 passes
Autoaddress: 0 # If NZ, auto-generate user addresses based on name
Daily_exit: 0 # If NZ, auto-restart each day after maintenance
Alt_Forward: 0 # If NZ, allow alternate forwarding specification
Maint_hour: 2 # Hour for daily maintenance (24-hour clock)
Retry_Mode: 0 # If NZ, use progressive backoff for queue retries
Local_DSNs: 1 # If NZ generate Delivery Status for local users only
DSN_time1: 10800 # Seconds deferred before first DSN is sent
DSN_time2: 86400 # Seconds deferred before second DSN is sent
DSN_time3: 259200 # Seconds deferred before third DSN is sent
Host_in_title: 0 # If NZ, show hostname in system tray and taskbar
Lingering: 0 # Enable or disable 'lingering mailboxes'
Linger_Timeout: 60 # Seconds before a lingering mailbox is shut down
Alert_Host: notify.pmail.com # Host to check for licensee advisories
Alert_Interval: 720 # Frequency in minutes (min 240) for checks
Alert_Flags: 3 # Flags controlling advisory checks
[MercuryC]
# Session_logging: G:\ # Directory to write session transcripts
host: # mail mail host which relays for us
scratch: C:\xampp\MERCURYMAIL\Mercury # Where we can write temp files
failfile: C:\xampp\MERCURYMAIL\Mercury\FAILURE.MER # Delivery failure template
[MercuryE]
Poll : 15
Timeout : 60
# Session_logging : o:\mail\mercury\melogs
# Session_logmode : 1
[MercuryD]
scratch : C:\xampp\MERCURYMAIL\Mercury
# Timeout : 30
[MercuryS]
Debug : 1
HELO : CS SMTP
Logfile : C:\xampp\MERCURYMAIL\Logs\MERCURYS.LOG
Timeout : 30
Relay : 0
Strict_Relay : 0
Interface : 127.0.0.1
Allow_Illegals : 0
SMTP_Authentication : 0
Compliance_Settings : 0
Maximum_Failed_Rcpts : 4
Max_Relay_Attempts : 4
SSL_Mode : 0
ST_Blacklisting : 288
No_VRFY : 0
SMTP_ConnFlags : 0
[MercuryP]
Scratch : C:\xampp\MERCURYMAIL\Mercury
Stack : 32768
Mark_Read : 1
SSL_Mode : 0
Login_Disabled : 0
UIDL_nul_list : 1
New_UIDs : 0
Timeout : 60
[MercuryX]
# Cmd_Delay: 10
# Cmd_Wait: 1
# IE4_Dialling: 0
# Use_ETRN: 1
# Clients_only: 1
# [Groups]
[Domains]
localhost: localhost
localhost: localhost.net
localhost: localhost.org
localhost: localhost.com
[Maiser]
Helpfile: C:\xampp\MERCURYMAIL\Mercury\MAISER.HLP # Help sent on failed maiser requests
Lookupfile: C:\xampp\MERCURYMAIL\Mercury\MAISER.LKP # Format file for the 'lookup' command
Send_dir: C:\xampp\MERCURYMAIL\Mercury\SENDABLE # Directory for the 'send' command
Logfile: C:\xampp\MERCURYMAIL\Logs\MAISER.LOG # Mail server log file
Notify: C:\xampp\MERCURYMAIL\Mercury\TMP # Dir. for pending 'notify' commands
[MercuryH]
Logfile : C:\xampp\MERCURYMAIL\Logs\MERCURYH.LOG
Timeout : 30
[MercuryI]
Scratch : C:\xampp\MERCURYMAIL\SCRATCH
Timeout : 120
Server_Port : 143
Idle_Timeout : 1800
SSL_Mode : 0
Login_Disabled : 0
[MercuryB]
# Logfile : o:\mail\tmp\mercuryb.log
Timeout : 120
Server_Port : 2224
# Session_logging : o:\mail\mercury\mblogs
# Session_logmode : 0
Idle_Timeout : 1800
[Groups]
[Rewrite]
[Statistics]
StatFlags: 0 # Statistical reporting settings
STM_Hours: 24 # How often to e-mail stat log files
at the admins page http://localhost/joomla/administrator/index.php?option=com_messages
Strict Standards: call_user_func_array() expects parameter 1 to
be a valid callback, non-static method JHtmlMessages::state() should not
be called statically in C:\xampp\htdocs\joomla\libraries\joomla\html\html.php on line 222
in the Mozilla Thunderbird wenn the user get emails from admin
Please log in to http://localhost/joomla/administrator/index.php?option=com_messages&view=message&message_id=30 to read your message.
when I click the link
You are not authorised to view this resource.
Finally I Hope you understand my probelm!
Please start by verifying if Mercury is installed in C:\MERCURY\ or C:\xampp\MERCURYMAIL\. It should be either, not both, and you need to know which.
You can perhaps use Mr. Seckinger's guide to help you set up a mail server for local use. If it however fails we are happy to give you advise on how to configure Mercury here, but specific questions regarding Mr. Seckinger's configuration example should probably be answered by him.
The address to the Joomla community site is http://forum.joomla.org/.
The MercuryMail is in C:\xampp\MercuryMail installed. where I can find Mr. Seckinger's guide??
[quote user="gazi"]The MercuryMail is in C:\xampp\MercuryMail installed. where I can find Mr. Seckinger's guide?? [/quote]
I would not recommend the guide that you linked to. Configuring an email server can be complex. The guide is far too simple, lacks explanation, and may expose the server on the internet to being hijacked as an open relay.
Use the help that Rolf suggests.
