> My settings:
> POP3 - login entered, but no password (I'm asked at first check)
> SMTP - "Login to SMTP server using POP3 username/password"
> When I enter password in pop3 or smtp settings everything works fine.
> So it seems that Pegasus try login with blank password and don't use
> this entered when checking new mail.
> Is this behaviour normal or its some kind of bug?
Normal.  The SMTP process is not an interactive protocol it just reads what to have in the password entry and sends it to the server.   You need to manually enter the username and password in the SMTP security setup if you want to leave the POP3 setup password blank.
<div>&gt; My settings:</div><div>&gt; POP3 - login entered, but no password (I'm asked at first check)</div><div>&gt; SMTP - "Login to SMTP server using POP3 username/password"</div><div>&gt;</div><div>&gt; When I enter password in pop3 or smtp settings everything works fine.</div><div>&gt; So it seems that Pegasus try login with blank password and don't use</div><div>&gt; this entered when checking new mail.&nbsp;</div><div>&gt;</div><div>&gt; Is this behaviour normal or its some kind of bug?</div><div>
</div><div>Normal. &nbsp;The SMTP process is not an interactive protocol it just reads what to have in the password entry and sends it to the server. &nbsp; You need to manually enter the username and password in the SMTP security setup if you want to leave the POP3 setup password blank.</div>
