Hello
i've got an issue with Mercury using the Autoreply (AREPLY.PM) method. using mercuryC module to send through a smarthost everything works fine until i try to use the AREPLY.PM file where the core will process it no problem, but when the smtp tries to send the job it fails with a 550 premission error. looking at the mercuryC logs i can see that the FROM field is just <> with no email address. Any other mail gets sent has <emailaddress@domain.com>, which is i'm guessing why it fails.
I've checked both alias and synonym files are there and functioning and am not sure whether i've just missed a simple entry in the config somewhere about default email addresses OR this is how it's meant to be?
any ideas on how to get the autoreply to function like it's coming from the user email?
thanks in advance
skuhtu
<p>Hello</p><p>i've got an issue with Mercury using the Autoreply (AREPLY.PM) method. using mercuryC module to send through a smarthost everything works fine until i try to use the AREPLY.PM file where the core will process it no problem, but when the smtp tries to send the job it fails with a 550 premission error. looking at the mercuryC logs i can see that the FROM field is just &lt;&gt; with no email address. Any other mail gets sent has &lt;emailaddress@domain.com&gt;, which is i'm guessing why it fails.</p><p>I've checked both alias and synonym files are there and functioning and am not sure whether i've just missed a simple entry in the config somewhere about default email addresses OR this is how it's meant to be?</p><p>any ideas on how to get the autoreply to function like it's coming from the user email?</p><p>thanks in advance</p><p>skuhtu&nbsp;</p>
