Hi!
Password has 7 characters, so should not be too long ;-)
Session log for "SSL with direct connection":
12:24:25.454: --- Wed May 30 12:24:25 2012 ---
12:24:25.454: Connect to 'pop3.live.com:995', timeout 30.
12:24:25.063: 22: Error -32 activating SSL session (locus 6014, type 4, code 0, 'Server provided a broken/invalid certificate, try again with')
12:24:25.063: --- Connection closed normally at Wed May 30 12:24:25 2012. ---
12:24:25.063:
Session log for "STLS command":
12:23:01.266: --- Wed May 30 12:23:01 2012 ---
12:23:01.266: Connect to 'pop3.live.com:995', timeout 30.
12:23:31.438: 8: NB Socket read timeout
12:23:31.438: --- Connection closed normally at Wed May 30 12:23:31 2012. ---
12:23:31.438:
Not sure which setting for the SSL connection should be the used but according to the session log, the direct command seems to be the one...
btw: Thunderbird has no problem to connect to this hotmail account using SSL 995.
Any ideas?
Konrad
<p>Hi!
</p><p>Password has 7 characters, so should not be too long ;-)</p><p>Session log for "SSL with direct connection":</p><p>12:24:25.454: --- Wed May 30 12:24:25 2012 ---
12:24:25.063:&nbsp;
</p><p>Session log for "STLS command":</p><p>12:23:01.266: --- Wed May 30 12:23:01 2012 ---
12:23:31.438:&nbsp;</p><p>&nbsp;</p><p>Not sure which setting for the SSL connection should be the used but according to the session log, the direct command seems to be the one...</p><p>btw: Thunderbird has no problem to connect to this hotmail account using SSL 995.
</p><p>Any ideas?</p><p>Konrad
</p><p>&nbsp;</p>
