[quote user="toncho11"]
How Can I use Mercury/32 for 2 domains? I have to use two installations? Wouldn't be a problem with ports?
I want to use one machine for both my domains.
Thanks!
Toncho
There are a couple of ways. The easy way is to just add the second domain in the domains section. All users are members of both domains, one would be the primary domain. The DNS would point both domains to the same IP address. The other method is to run two separate installations and bind two different IP addresses to either the same card or use two different cards.
[quote user="toncho11"]<p>Hi,</p><p>&nbsp;How Can I use Mercury/32 for 2 domains? I have to use two installations? Wouldn't be a problem with ports? </p><p>I want to use one machine for both my domains.</p><p>&nbsp;Thanks!</p><p>&nbsp;</p><p>Toncho
&nbsp;</p><p>[/quote]</p><p>There are a couple of ways.&nbsp; The easy way is to just add the second domain in the domains section.&nbsp; All users are members of both domains, one would be the primary domain.&nbsp; The DNS would point both domains to the same IP address.&nbsp; The other method is to run two separate installations and bind two different IP addresses to either the same card or use two different cards.&nbsp;
</p><p>&nbsp;</p>
