[quote user="erchess"]
Ok the only way I can see the address book is by opening an email then clicking the addressbook icon. A box opens up and I can in a two step process put any address into the relevant field of the email but I see no tabs and I see no other way to edit the address book. I must be missing something because the address book has to be easily editable or Pegasus would not have the following it has.
Oh wait from the inbox if I hit F3 I get the address book added to that list of things near the top. When I click that word addressbook I get a tab with several choices, some of which I used to get my contact list into Pegasus. But I don't see any tabs at all.
With "Address book" open you should see a choice of Address books or Distribution lists. If you open the Address book tab you should see under "description" a list of address books and then under "Name" a list of names in the highlighted address book.
[quote user="erchess"]<p>Ok the only way I can see the address book is by opening an email then clicking the addressbook icon. A box opens up and I can in a two step process put any address into the relevant field of the email but I see no tabs and I see no other way to edit the address book. I must be missing something because the address book has to be easily editable or Pegasus would not have the following it has.</p><p>Oh wait from the inbox if I hit F3 I get the address book added to that list of things near the top. When I click that word addressbook I get a tab with several choices, some of which I used to get my contact list into Pegasus. But I don't see any tabs at all.
</p><p>[/quote]</p><p>With "Address book" open you should see a choice of Address books or Distribution lists. If you open the Address book tab you should see under "description" a list of address books and then under "Name" a list of names in the highlighted address book.
