Hi!
As you would have been able to see, on the screen shots, which I cannot attach because they are too big, I have 1 (or 2!) mail message(s), both with the following headers:
To: Henrik Rosenø <henrik.roseno@webspeed.dk>
Subject: Ikke til stede: Miljøvenlige alternativer ti l salt mod is på fortovene
Date sent: Thu, 5 Jan 2012 20:35:00 +0100
(The 2 messages also have same contents.)
But, as you can also not see on the screen shots, Pegasus - Edit-menu -> Find text (Ctrl-F) cannot find this/these message(s), if I search for 'Karsten ikke til stede', regardless of whether I search in headers only or not. This is strange!
And it gets stranger:
If I view the second message and Escape message-view, the cursor is now on the first message.
Checking folder consistency and re-indexing the folder doesn't change any of the above.
And if I delete one of them, in folder-view, they both disappear.
Best regards,
Henrik Rosenø
<p>Hi!
</p><p>As you would have been able to see, on the screen shots, which I cannot attach because they are too big, I have 1 (or 2!) mail message(s), both with the following headers: </p><p>&nbsp;&nbsp;&nbsp; From:&nbsp;&nbsp;&nbsp; Karsten Klintø &lt;kakl01@frederiksberg.dk&gt;
&nbsp;&nbsp;&nbsp; To:&nbsp;&nbsp;&nbsp; Henrik Rosenø &lt;henrik.roseno@webspeed.dk&gt;
&nbsp;&nbsp;&nbsp; Subject:&nbsp;&nbsp;&nbsp; Ikke til stede: Miljøvenlige alternativer ti l salt mod is på fortovene
&nbsp;&nbsp;&nbsp; Date sent:&nbsp;&nbsp;&nbsp; Thu, 5 Jan 2012 20:35:00 +0100 </p><p>(The 2 messages also have same contents.)
</p><p>But, as you can also not see on the screen shots, Pegasus - Edit-menu -&gt; Find text (Ctrl-F) cannot find this/these message(s), if I search for 'Karsten ikke til stede', regardless of whether I search in headers only or not. This is strange!
And it gets stranger: </p><p>If I view the second message and Escape message-view, the cursor is now on the first message.
</p><p>Checking folder consistency and re-indexing the folder doesn't change any of the above.</p><p>And if I delete one of them, in folder-view, they both disappear.
</p><p>Best regards,</p><p>Henrik Rosenø </p>
