"bfluet,"
In part to your message, YES, you are correct about the "I:\" being the Micro Mini Chip and the IDs of the 'Home' and "ADMIN" mail boxes. Now about that file I Edited with EditPad Lite v7.x my preferred editor, not using NotePad. The file I edited is "PMail.ini" in the folder ADMIN. The mail boxes are not the same as I use or monitor three (3) different email addies yet use only one access or user account, ADMIN.
A little explanation here, I moved the entire folder + sub-folders to a safe location, out of the PMail folder, of the Micro Mini Chip, that contained Programs folder as well. Used VS Group Revo Uninstaller to remove Pegasus Mail. Downloaded a fresh copy and created a ICON link to run install with -ROAM command line creating desktop icon for ADMIN and under Start Menu for Win7 64bit. Cannot remember all of what I had done to get where I am now, but; I did something right because all of my hook-ups to my mail server went without a problem. I have three (3) email addies I am monitoring and they are all AOK! None of my mail boxes have shown in Pegasus Mail, have had to create some to save a few messages. None of my SPAMHalter has made it over to this new install.
The edited file is "PMail.ini" in the ADMIN folder in the Mail folder of my Micro Mini Chip. The top five (5) lines of that file were like these are: (they are from the saved copy)
"[General]
Personal name = 'd'
Home mailbox location = O:\PMAIL\MAIL
Folder for copies to self = Mine
Commenting string = "> " "
The HOME mail box line is the one I edited, this is from the original .INI file and has not been edited so I have this info for you. I also have a USB H/D 320 gig partitioned out to "O:" yet there is not a folder on that drive as identified above. When I used Pegasus to make the change to "I:\PMail\Mail" then ticked the check box then 'Move now' nothing took place, not once but several times. Even with the chcek box un-ticked, Pegasus did not shut down as explained in the instructions on that page. When I moved elsewhere to check mail or read or whatever and returned that was still "O:" and that is when started to investigate where that was being stored and found it in the 'PMail.ini' file. That file is the one that is within the "I:|PMail]Mail\ADMIN" edited to correct that issue. This shown above is from my original.
It is now showing correctly within Pegasus Mail under Tools/Options/General Settings/Mailbox location. Have not started into your further instructions yet. Attempting to get this straight and clear. Will post this much before going on with the remainder.
Edited by NTxLS to add below
As for these ".CNM, .PMM, .PMI, .PML, & .PRM" it is like this, ".CNM" there are not any; ".PRM" may just be ".PMR: as there are not any as the former; the other, ".PMM, .PML, .PMI," are there. Explorer has the ability to display just the files I want sorted by the extensions. I moved the "Type" before the file names so they are easier to select and highlight for the move.
I await your verdict on the PRM vx ".PMR" and none of the ".CNM", In the drop down listing for the "Type" there is not a listing for ".CNM" is there another to replace that one?
<p>"bfluet,"</p><p>In part to your message, YES, you are correct about the "I:\" being the Micro Mini Chip and the IDs of the 'Home' and "ADMIN" mail boxes.&nbsp; Now about that file I Edited with EditPad Lite v7.x my preferred editor, not using NotePad.&nbsp; The file I edited is "PMail.ini" in the folder ADMIN.&nbsp; The mail boxes are not the same as I use or monitor three (3) different email addies yet use only one access or user account, ADMIN.
</p><p>A little explanation here, I moved the entire folder + sub-folders to a safe location, out of the PMail folder, of the Micro Mini Chip, that contained Programs folder as well.&nbsp; Used VS Group Revo Uninstaller to remove Pegasus Mail.&nbsp; Downloaded a fresh copy and created a ICON link to run install with -ROAM command line creating desktop icon for ADMIN and under Start Menu for Win7 64bit.&nbsp; Cannot remember all of what I had done to get where I am now, but; I did something right because all of my hook-ups to my mail server went without a problem.&nbsp; I have three (3) email addies I am monitoring and they are all AOK!&nbsp; None of my mail boxes have shown in Pegasus Mail, have had to create some to save a few messages.&nbsp; None of my SPAMHalter has made it over to this new install.</p><p>The edited file is "PMail.ini" in the ADMIN folder in the Mail folder of my Micro Mini Chip.&nbsp; The top five (5) lines of that file were like these are: (they are from the saved copy)
</p><p>"[General]
Personal name&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; = 'd'
Home mailbox location&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; = O:\PMAIL\MAIL
Folder for copies to self&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; = Mine
Commenting string&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; = "&gt; " "</p><p>The HOME mail box line is the one I edited, this is from the original .INI file and has not been edited so I have this info for you.&nbsp; I also have a USB H/D 320 gig partitioned out to "O:" yet there is not a folder on that drive as identified above.&nbsp; When I used Pegasus to make the change to "I:\PMail\Mail" then ticked the check box then 'Move now' nothing took place, not once but several times.&nbsp; Even with the chcek box un-ticked,&nbsp; Pegasus did not shut down as explained in the instructions on that page.&nbsp; When I moved elsewhere to check mail or read or whatever and returned that was still "O:" and that is when started to investigate where that was being stored and found it in the 'PMail.ini' file.&nbsp; That file is the one that is within the "I:|PMail]Mail\ADMIN" edited to correct that issue.&nbsp; This shown above is from my original.</p><p>It is now showing correctly within Pegasus Mail under Tools/Options/General Settings/Mailbox location.&nbsp; Have not started into your further instructions yet.&nbsp; Attempting to get this straight and clear.&nbsp; Will post this much before going on with the remainder.</p><p>Edited by NTxLS to add below</p><p>&nbsp;As for these ".CNM, .PMM, .PMI, .PML, &amp; .PRM" it is like this,&nbsp; ".CNM" there are not any; ".PRM" may just be ".PMR: as there are not any as the former; the other, ".PMM, .PML, .PMI," are there.&nbsp; Explorer has the ability to display just the files I want sorted by the extensions.&nbsp; I moved the "Type" before the file names so they are easier to select and highlight for the move.</p><p>I await your verdict on the PRM vx ".PMR" and none of the ".CNM",&nbsp; In the drop down listing for the "Type" there is not a listing for ".CNM" is there another to replace that one?</p><p>&nbsp;</p><p>&nbsp;</p>
