Problems with migration of Pegasus on dual boot W7 and W8
I sounds like the Win8 install of Pegasus Mail is working in a new mailbox and not the one used by the Win7 installation.  In the Win8 install of Pegasus Mail, go the Help menu and select About Pegasus Mail... Click the Info button then look for the following entries to see what Pegasus is working with:
WINPMAIL.EXE directory:
Home mailbox location:
New mailbox location:
<p>I sounds like the Win8 install of Pegasus Mail is working in a new mailbox and not the one used by the Win7 installation.  In the Win8 install of Pegasus Mail, go the Help menu and select About Pegasus Mail... Click the Info button then look for the following entries to see what Pegasus is working with: </p><p>WINPMAIL.EXE directory: Home mailbox location: New mailbox location: </p><p> </p>
<!--[if gte mso 9]><xml> </p><p> <w:WordDocument> </p><p> <w:View>Normal</w:View> </p><p> <w:Zoom>0</w:Zoom> </p><p> <w:TrackMoves/> </p><p> <w:TrackFormatting/> </p><p> <w:HyphenationZone>21</w:HyphenationZone> </p><p> <w:PunctuationKerning/> </p><p> <w:ValidateAgainstSchemas/> </p><p> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> </p><p> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> </p><p> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> </p><p> <w:DoNotPromoteQF/> </p><p> <w:LidThemeOther>NL</w:LidThemeOther> </p><p> <w:LidThemeAsian>X-NONE</w:LidThemeAsian> </p><p> <w:LidThemeComplexScript>X-NONE</w:LidThemeComplexScript> </p><p> <w:Compatibility> </p><p> <w:BreakWrappedTables/> </p><p> <w:SnapToGridInCell/> </p><p> <w:WrapTextWithPunct/> </p><p> <w:UseAsianBreakRules/> </p><p> <w:DontGrowAutofit/> </p><p> <w:SplitPgBreakAndParaMark/> </p><p> <w:DontVertAlignCellWithSp/> </p><p> <w:DontBreakConstrainedForcedTables/> </p><p> <w:DontVertAlignInTxbx/> </p><p> <w:Word11KerningPairs/> </p><p> <w:CachedColBalance/> </p><p> </w:Compatibility> </p><p> <m:mathPr> </p><p> <m:mathFont m:val="Cambria Math"/> </p><p> <m:brkBin m:val="before"/> </p><p> <m:brkBinSub m:val="&#45;-"/> </p><p> <m:smallFrac m:val="off"/> </p><p> <m:dispDef/> </p><p> <m:lMargin m:val="0"/> </p><p> <m:rMargin m:val="0"/> </p><p> <m:defJc m:val="centerGroup"/> </p><p> <m:wrapIndent m:val="1440"/> </p><p> <m:intLim m:val="subSup"/> </p><p> <m:naryLim m:val="undOvr"/> </p><p> </m:mathPr></w:WordDocument> </p><p></xml><![endif]-->
Have been
using Pegasus version 4.63 build 325 on a W7 64bit (ultimate) system without problems.
Decided to make use of the Microsoft offer and to migrate slowly to W8 64bit (prof).
On W7 the
mailbox is located on a partition with other data. Loaded Pegasus into W8 and connected
it to the same mailbox as used in W7. All folders are visible and can be
opened. However, the New Mail folder, the identities and network configuration
are completely empty.
Under W7
the program remains functioning fine.
Any suggestion for cause and/or solution.
&lt;!--[if gte mso 9]&gt;&lt;xml&gt; &lt;w:WordDocument&gt; &lt;w:View&gt;Normal&lt;/w:View&gt; &lt;w:Zoom&gt;0&lt;/w:Zoom&gt; &lt;w:TrackMoves/&gt; &lt;w:TrackFormatting/&gt; &lt;w:HyphenationZone&gt;21&lt;/w:HyphenationZone&gt; &lt;w:PunctuationKerning/&gt; &lt;w:ValidateAgainstSchemas/&gt; &lt;w:SaveIfXMLInvalid&gt;false&lt;/w:SaveIfXMLInvalid&gt; &lt;w:IgnoreMixedContent&gt;false&lt;/w:IgnoreMixedContent&gt; &lt;w:AlwaysShowPlaceholderText&gt;false&lt;/w:AlwaysShowPlaceholderText&gt; &lt;w:DoNotPromoteQF/&gt; &lt;w:LidThemeOther&gt;NL&lt;/w:LidThemeOther&gt; &lt;w:LidThemeAsian&gt;X-NONE&lt;/w:LidThemeAsian&gt; &lt;w:LidThemeComplexScript&gt;X-NONE&lt;/w:LidThemeComplexScript&gt; &lt;w:Compatibility&gt; &lt;w:BreakWrappedTables/&gt; &lt;w:SnapToGridInCell/&gt; &lt;w:WrapTextWithPunct/&gt; &lt;w:UseAsianBreakRules/&gt; &lt;w:DontGrowAutofit/&gt; &lt;w:SplitPgBreakAndParaMark/&gt; &lt;w:DontVertAlignCellWithSp/&gt; &lt;w:DontBreakConstrainedForcedTables/&gt; &lt;w:DontVertAlignInTxbx/&gt; &lt;w:Word11KerningPairs/&gt; &lt;w:CachedColBalance/&gt; &lt;/w:Compatibility&gt; &lt;m:mathPr&gt; &lt;m:mathFont m:val=&quot;Cambria Math&quot;/&gt; &lt;m:brkBin m:val=&quot;before&quot;/&gt; &lt;m:brkBinSub m:val=&quot;&amp;#45;-&quot;/&gt; &lt;m:smallFrac m:val=&quot;off&quot;/&gt; &lt;m:dispDef/&gt; &lt;m:lMargin m:val=&quot;0&quot;/&gt; &lt;m:rMargin m:val=&quot;0&quot;/&gt; &lt;m:defJc m:val=&quot;centerGroup&quot;/&gt; &lt;m:wrapIndent m:val=&quot;1440&quot;/&gt; &lt;m:intLim m:val=&quot;subSup&quot;/&gt; &lt;m:naryLim m:val=&quot;undOvr&quot;/&gt; &lt;/m:mathPr&gt;&lt;/w:WordDocument&gt; &lt;/xml&gt;&lt;![endif]--&gt; &lt;p class=&quot;MsoNormal&quot;&gt;&lt;span style=&quot;mso-ansi-language:EN-GB&quot; lang=&quot;EN-GB&quot;&gt;Have been using Pegasus version 4.63 build 325 on a W7 64bit (ultimate) system without problems. Decided to make use of the Microsoft offer and to migrate slowly to W8 64bit (prof).&lt;/span&gt;&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;&lt;span style=&quot;mso-ansi-language:EN-GB&quot; lang=&quot;EN-GB&quot;&gt;On W7 the mailbox is located on a partition with other data. Loaded Pegasus into W8 and connected it to the same mailbox as used in W7. All folders are visible and can be opened. However, the New Mail folder, the identities and network configuration are completely empty.&lt;/span&gt;&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;&lt;span style=&quot;mso-ansi-language:EN-GB&quot; lang=&quot;EN-GB&quot;&gt;Under W7 the program remains functioning fine.&lt;span style=&quot;mso-spacerun:yes&quot;&gt;&amp;nbsp; &lt;/span&gt;Any suggestion for cause and/or solution. &lt;span style=&quot;mso-spacerun:yes&quot;&gt;&amp;nbsp;&lt;/span&gt;&lt;span style=&quot;mso-spacerun:yes&quot;&gt;&amp;nbsp;&lt;/span&gt;&lt;span style=&quot;mso-spacerun:yes&quot;&gt;&amp;nbsp;&lt;/span&gt;&lt;/span&gt;&lt;/p&gt;&lt;p class=&quot;MsoNormal&quot;&gt; &lt;/p&gt;
