[quote user="janhaverkamp"]Ahoj Michael - feeling very honoured to get the response from you personally :-) [/quote]
I'm afraid nobody else would have a good answer for you: I don't really think a lot people are still using encryption at all these days ...
[quote user="janhaverkamp"]The AutoList could be the problem. I had imported the full list of certificates that I got - several thousands of addresses and I will need less than 1% of them...
Just add or keep the ones you need ...
With "disable of enable various features", what do you mean?
As such, I don 't need an AutoList - I now switched off the Auto Encryption in the configuration -> encoding menu and that gives instant sending again when not encrypted and a bit, but acceptable, waiting time for encyption.[/quote]
That's exactly what I meant and it served its purpose obviously.
<p>[quote user="janhaverkamp"]Ahoj Michael - feeling very honoured to get the response from you personally :-) [/quote]</p><p>I'm afraid nobody else would have a good answer for you: I don't really think a lot people are still using encryption at all these days ...</p><p>[quote user="janhaverkamp"]The AutoList could be the problem. I had imported the full list of certificates that I got - several thousands of addresses and I will need less than 1% of them...
[/quote]</p><p>Just add or keep the ones you need ...</p><p>[quote user="janhaverkamp"]
With "disable of enable various features", what do you mean?</p><p>As such, I don 't need an AutoList - I now switched off&nbsp; the Auto Encryption in the configuration -&gt; encoding menu and that gives instant sending again when not encrypted and a bit, but acceptable, waiting time for encyption.[/quote]</p><p>That's exactly what I meant and it served its purpose obviously.</p>
