HELP! Can't create, delete or rename folders
Is the space at the top of that window, where the icons and/or text normaly resides still there - even empty?
If not, close  Pegasus, rename STATE.PMJ in you mailbox and restart Pegasus.
If yes the folder with the icons (PNG in programdiretory) or some of them may be lost. *Ups* PM441 - may be that folder doesn't exist at all in that version - don't remember.
<p>Is the space at the top of that window, where the icons and/or text normaly resides still there - even empty?</p><p>If not, close  Pegasus, rename STATE.PMJ in you mailbox and restart Pegasus.</p><p>If yes the folder with the icons (PNG in programdiretory) or some of them may be lost. *Ups* PM441 - may be that folder doesn't exist at all in that version - don't remember. </p><p> </p>
I'm desperate!
I'm running PMail v4.41 under Windows 7. The reason I have not
upgraded is because in newer versions, the shift+F3 expansion of names
to email address no longer works.
Recently, when opening the
Folders window, all of the buttons at the top (New, Delete, Rename, etc)
have disappeared.
I can find no other way to create, rename or delete a folder. This is really getting to be troublesome for my filing system!
Any ideas?
Ros.
I'm desperate! <p>I'm running PMail v4.41 under Windows 7. The reason I have not upgraded is because in newer versions, the shift+F3 expansion of names to email address no longer works.</p><p>Recently, when opening the Folders window, all of the buttons at the top (New, Delete, Rename, etc) have disappeared.</p><img src="http://community.pmail.com/forums/data:image/png;base64,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" alt=""> I can find no other way to create, rename or delete a folder. This is really getting to be troublesome for my filing system! <p>Any ideas?</p><p>Thanks,</p>Ros.
Any chance the top of the folder window is outside the main Pegasus Mail window?  If so, go to the Window pull down menu and select Tile. This will make all open windows visible and you can then arrange/resize as needed.
<p>Any chance the top of the folder window is outside the main Pegasus Mail window?  If so, go to the Window pull down menu and select Tile. This will make all open windows visible and you can then arrange/resize as needed.</p><p> </p>
[quote user="ros_b"]I'm desperate!
Ros.[/quote]
You probably need to rethink the value of that vs the features of the upgraded version.
[quote user="ros_b"]I'm desperate! <p>I'm running PMail v4.41 under Windows 7. The reason I have not upgraded is because in newer versions, the shift+F3 expansion of names to email address no longer works.</p><p>Ros.[/quote]</p><p>You probably need to rethink the value of that vs the features of the upgraded version. </p>
