May be me...but strange printing problem
Check the Printer setup, there may be a Page Eject/Feed (PE or PF) setting that is happening in addition to the incoming print feed already ending with PE/PF.
<p>Check the Printer setup, there may be a Page Eject/Feed (PE or PF) setting that is happening in addition to the incoming print feed already ending with PE/PF.</p><p> </p>
I use a canon MG5320 wireless printer....it always "sees" a print from Peg as an image and wants rear fed paper. It is set to default to lower casette for plain paper and will not allow me to make it use the casette and not the rear fed photo paper.
This only happens from Pegasus and is the only printer and is set as default. Word/Notepad are fine as are photo's.....both set the paper correctly (printer defaults)
 Anyone else having a problem or is it this particular printer/my glitch  ??
Peter
<p>I use a canon MG5320 wireless printer....it always "sees" a print from Peg as an image and wants rear fed paper. It is set to default to lower casette for plain paper and will not allow me to make it use the casette and not the rear fed photo paper.</p><p>This only happens from Pegasus and is the only printer and is set as default. Word/Notepad are fine as are photo's.....both set the paper correctly (printer defaults)</p><p> Anyone else having a problem or is it this particular printer/my glitch  ??</p><p>Peter</p>
I have the same problem with the Canon printer I have at home.  Seems unique to Canon since I have Brother, Xerox and Dell printers at the office that work fine.
<p>I have the same problem with the Canon printer I have at home.  Seems unique to Canon since I have Brother, Xerox and Dell printers at the office that work fine.</p><p>  </p>
