Hi -
I've been a very happy Pegasus user since 1996, on several PCs and Windows OSs.
Lately, I've been using PM 4.63, build 325 on my 2008 Acer twin processor PC, running on Windows Vista.
Pegasus runs fine, however, my processor capacity window in Task Manager shows that Pegasus almost contstantly soaks up exactly 50% of processor capacity, when IDLE.
If I check for mail, this insane processor load stops and Pegasus only uses a couple of percent, which is normal.
Shortly after the mail is checked for, this 50% load on the processors by Pegasus starts up again.
Note: When I installed this version of Pegasus, this did not happen. It's recent, sometime in the past few months.
Any tips on how to correct this will be appreciated.
Eleanor White
<p>Hi -</p><p>I've been a very happy Pegasus user since 1996, on several PCs and Windows OSs.</p><p>Lately, I've been using PM 4.63, build 325 on my 2008 Acer twin processor PC, running on Windows Vista.</p><p>Pegasus runs fine, however, my processor capacity window in Task Manager shows that Pegasus almost contstantly soaks up exactly 50% of processor capacity, when IDLE.</p><p>If I check for mail, this insane processor load stops and Pegasus only uses a couple of percent, which is normal.</p><p>Shortly after the mail is checked for, this 50% load on the processors by Pegasus starts up again.</p><p>Note:&nbsp; When I installed this version of Pegasus, this did not happen.&nbsp; It's recent, sometime in the past few months.</p><p>Any tips on how to correct this will be appreciated.
</p><p>Eleanor White</p><p>&nbsp;</p>
