Brian:
To be more specific, I removed the entire C:\Pmail folder from the hard drive and put it on a USB stick. I think took a different entire C:\Pmail folder and copied it to this machine.
Here it is.
Copyright (C) 1992-2011, David Harris, all rights reserved
WinPMail version: Version 4.63 (Win32), Dec 22 2011, build ID 325
Windows version: 5.1
WINPMAIL.EXE directory: C:\PMAIL
Home mailbox location: C:\PMAIL\MAIL
New mailbox location: C:\PMAIL\MAIL
TMP environment variable: J:\DOCUME~1\Owner\LOCALS~1\Temp
TEMP environment variable: J:\DOCUME~1\Owner\LOCALS~1\Temp
- WINSOCK path: J:\WINDOWS\system32\WSOCK32.DLL
Commandline:
Active -Z options: 32768
PMR variable: (None)
PML variable: (None)
MAI variable: (None)
NB variable: (None)
Last new mail count: 4
<p>Brian:</p><p>&nbsp;To be more specific, I removed the entire C:\Pmail folder from the hard drive and put it on a USB stick. I think took a different entire C:\Pmail folder and copied it to this machine. </p><p>&nbsp;</p><p>Here it is.
</p><p>&nbsp;*******</p><p>&nbsp;Pegasus Mail for Microsoft Windows
&nbsp; - WINSOCK version: WinSock 2.0
&nbsp; - WINSOCK path: J:\WINDOWS\system32\WSOCK32.DLL
Commandline:
NB variable: (None)
