Deleting 'System Wide' mailbox
[quote user="bfluet"]
Did you try deleting the public folder using Tools > Public Folders?
Duuuhhhh!
 Thanks ...
[quote user="bfluet"]<p>Did you try deleting the public folder using Tools > Public Folders?</p><p> </p><p>[/quote]</p><p> </p><p>Duuuhhhh!</p><p> Thanks ...</p><p> </p>
Out of interest I set up a system wide mailbox in which to move all family mail for both my wife and I to have access regardless of which it was addressed to. For reasons not worth elaborating I decided it wasn't working how I had anticipated. After deleting all the messages and folders under the mail box, I find I can't delete the mailbox itself. At least not in the Folders window of Pegasus while it's open and running. I see there is a "Public" folder in the C:\Pmail\Mail directory which is 1) empty and 2) I presume is the sticky mailbox. Is it safe to just delete that folder from the ..\Mail directory?
Thanks -
<p>Out of interest I set up a system wide mailbox in which to move all family mail for both my wife and I to have access regardless of which it was addressed to. For reasons not worth elaborating I decided it wasn't working how I had anticipated. After deleting all the messages and folders under the mail box, I find I can't delete the mailbox itself. At least not in the Folders window of Pegasus while it's open and running. I see there is a "Public" folder in the C:\Pmail\Mail directory which is 1) empty and 2) I presume is the sticky mailbox. Is it safe to just delete that folder from the ..\Mail directory?</p><p> </p><p>Thanks -</p><p> </p><p> </p>
