SendDoc 1.5 for OpenOffice/LibreOffice interface
Try this one:
http://community.pmail.com/files/folders/pegadd/entry38101.aspx
<p>Try this one:</p><p>http://community.pmail.com/files/folders/pegadd/entry38101.aspx</p><p> </p>
This small update allows blank characters in filenames, as well as the pathnames (already supported).
Download from:  http://community.pmail.com/files/folders/pegadd/entry38072.aspx
<p>This small update allows blank characters in filenames, as well as the pathnames (already supported).</p><p>Download from:  http://community.pmail.com/files/folders/pegadd/entry38072.aspx </p><p>Martin </p>
Link leads to:
Resource not found
The resource you requested does not exist.
I believe it should be - http://community.pmail.com/files/folders/pegadd/entry38101.aspx
<p>Link leads to:</p><p>Resource not found The resource you requested does not exist.</p><p>I believe it should be - http://community.pmail.com/files/folders/pegadd/entry38101.aspx</p>
