[quote user="Okie_LEO"]I can set up folders in Pegasus Mail for the messages I would normally want to save in My Documents, hold them there as long as needed, and then delete them when I'm ready. If I'm following you right I think I should be able to get everything set-up okay, with the key words in that being "should be".[/quote]
I recommend easing into Pegasus Mail if you have that luxury. It's not that Pegasus Mail is difficult but it is different. I mentioned the importance of getting familiar with the concepts of Users and Identities but it sounds like it would benefit you to actually see and work with the folder structure before making Pegasus Mail your "production" email client.
In my previous post I mentioned a method of testing without deleting mail off the server. I suggest doing that. Install Pegasus Mail and configure it with just one of your accounts. In the POP3 host configuration be sure not to enable the "Delete mail from host once it has been successfully retrieved" setting". Now just play. Play with the folder structure, look at List mode vs. Preview mode. FWIW, I prefer List mode because it allows me to keep multiple folder windows open on my Pegasus Mail desktop. As an introduction to Identities you may want to create an Identity for this account. You would then have two identities (the first one being 'Default') with which to work with.
It will take a bit of effort to figure out the advanced capabilities of
Pegasus Mail so I hope you are the type who likes to figure out how to
get things to work better, faster and easier.
Be aware that HTML handing has been greatly improved since the release of v4.63 Pegasus Mail was released. These improvements come in the form of updated HTML renderers, one called IERenderer and the other called BearHTML. You will want to upgrade to the most current versions. Both are available in the downloads section of this community site.
A couple of other things worthy of knowing. Pegasus Mail must NOT be installed anywhere in the \Program Files directory. It won't work if you do, trust me on this. Stick with the default location of c:\pmail. This will also make it easier to troubleshoot any problems. Also, once Pegasus Mail is installed, maintain a backup of at least the mailbox directory(ies) but the whole \pmail directory would be better. This will make it much easier to recover in the event of a system crash or should you just totally screw something up while playing.
<p>[quote user="Okie_LEO"]I can set up folders in Pegasus Mail for the messages I would normally want to save in My Documents, hold them there as long as needed, and then&nbsp;delete them when I'm ready. If I'm following you right I think I should be able to get everything set-up okay, with&nbsp;the key words in that being "should be".[/quote]</p><p>I recommend easing into Pegasus Mail if you have that luxury.&nbsp; It's not that Pegasus Mail is difficult but it is different.&nbsp; I mentioned the importance of getting familiar with the concepts of Users and Identities but it sounds like it would benefit you to actually see and work with the folder structure before making Pegasus Mail your "production" email client.&nbsp; </p><p>In my previous post I mentioned a method of testing without deleting mail off the server.&nbsp; I suggest doing that.&nbsp; Install Pegasus Mail and configure it with just one of your accounts.&nbsp; In the POP3 host configuration be sure not to enable the "Delete mail from host once it has been successfully retrieved" setting".&nbsp; Now just play.&nbsp; Play with the folder structure, look at List mode vs. Preview mode.&nbsp; FWIW, I prefer List mode because it allows me to keep multiple folder windows open on my Pegasus Mail desktop.&nbsp; As an introduction to Identities you may want to create an Identity for this account.&nbsp; You would then have two identities (the first one being 'Default') with which to work with.</p><p>It will take a bit of effort to figure out the advanced capabilities of
</p><p>Be aware that HTML handing has been greatly improved since the release of v4.63 Pegasus Mail was released.&nbsp; These improvements come in the form of updated HTML renderers, one called IERenderer and the other called BearHTML.&nbsp; You will want to upgrade to the most current versions.&nbsp; Both are available in the downloads section of this community site. </p><p>A couple of other things worthy of knowing.&nbsp; Pegasus Mail must NOT be installed anywhere in the \Program Files directory.&nbsp; It won't work if you do, trust me on this.&nbsp; Stick with the default location of c:\pmail.&nbsp; This will also make it easier to troubleshoot any problems.&nbsp; Also, once Pegasus Mail is installed, maintain a backup of at least the mailbox directory(ies) but the whole \pmail directory would be better.&nbsp; This will make it much easier to recover in the event of a system crash or should you just totally screw something up while playing.</p>
