[quote user="bfluet"]
Will this help?
Tools > Options > User interface > Reporting/logging > Show System Message window after applying filtering rules
From the help file: If you check this control, Pegasus Mail will automatically open the System Message window any time filtering rules are applied to a folder and affect at least one message. This is a useful way of seeing at a glance what actions the filtering system has taken with your messages.
Thanks, that's what I have done and my work-around is based on those logging settings which in conjunction with an unread 'dummy' message in my inbox (which alway triggers a 'dummy' rule) makes the message window appear even when there is no other rule being triggered.
I thought there might be another switch to allow the message window to alway show.
[quote user="bfluet"]<p>Will this help?</p><p>Tools &gt; Options &gt; User interface &gt; Reporting/logging &gt;&nbsp; Show System Message window after applying filtering rules</p><p>From the help file:&nbsp;<i> If you check this control, Pegasus Mail will automatically open the System Message window any time filtering rules&nbsp; are applied to a folder and affect at least one message. This is a useful way of seeing at a glance what actions the filtering system has taken with your messages. </i></p><p>[/quote]</p><p>Thanks, that's what I have done and my work-around is based on those logging settings which in conjunction with an unread 'dummy' message in my inbox (which alway triggers a 'dummy' rule) makes the message window appear even when there is no other rule being triggered.
&nbsp;</p>
