Message Headers and Help Topics Don't Display Properly
I have been using PMail for well over ten years; this issue just cropped up. The reader header displays the "From" and "To" lines properly. However, in order to display the "Subject," "Date Sent,""Reply TO" and "CC" fields, I need to position the cursor after the end of the "To" line and click down arrow or page down. I can then view two more lines at a time. It does not matter how large I adjust the header field by dragging the bottom line of the field. That is, if the message header window is 10 lines high, I will see 8 blank lines.
I have the exact same problem with the help fields. If I press F1 or click on Help, then select a topic, I will see the title of the topic with a blank screen underneath. I can then read one or two lines at a time by positioning my cursor after the title then pressing down arrow; again, it does not matter how big the window is set, the two displayed lines will be followed by blank space.
I have tried resizing the window(s) by dragging the bottoms. It makes no difference in the behavior.
I am running 64 bit Windows 7.
<p>I have been using PMail for well over ten years; this issue just cropped up. The reader header displays the "From" and "To" lines properly. However, in order to display the "Subject," "Date Sent,""Reply TO" and "CC" fields, I need to position the cursor after the end of the "To" line and click down arrow or page down. I can then view two more lines at a time. It does not matter how large I adjust the header field by dragging the bottom line of the field. That is, if the message header window is 10 lines high, I will see 8 blank lines.</p><p>I have the exact same problem with the help fields. If I press F1 or click on Help, then select a topic, I will see the title of the topic with a blank screen underneath. I can then read one or two lines at a time by positioning my cursor after the title then pressing down arrow; again, it does not matter how big the window is set, the two displayed lines will be followed by blank space.</p><p><span style="font-size: 10pt;">I have tried resizing the window(s) by dragging the bottoms. It makes no difference in the behavior.</span></p><p>I am running<span style="font-size: 10pt;"> </span><span style="font-size: 10pt;">64 bit</span><span style="font-size: 10pt;"> Windows 7. </span></p><p> </p><p> </p><p> </p>
