Sorting problems
Are you using the three panel "Preview Mode"?
Look at:
  Tools > Options
  Preview mode settings
  [x] Remember and apply each folder's sorting mode separately
Exit Pegasus via the menu File > Exit
<P>Are you using the three panel "Preview Mode"?</P> <P>Look at:   Tools > Options   Preview mode settings   [x] Remember and apply each folder's sorting mode separately</P> <P>Exit Pegasus via the menu File > Exit </P>
Hello guys I have one quick question I have my inbox set : sort by date and they are sort by date...but in 2 folders one is called COPYSELF is set: sort by sender and sort in reverse order even though that I have change sort by date and then I quit and turn on again stays the same as it was does anyone has any solution for me???
Thanks in advance!
<p>Hello guys I have one quick question I have my inbox set : sort by date and they are sort by date...but in 2 folders one is called COPYSELF is set: sort by sender and sort in reverse order even though that I have change sort by date and then I quit and turn on again stays the same as it was does anyone has any solution for me???</p><p> </p><p>Thanks in advance! </p>
