IE Renderer problem
[quote user="sfleury"]Is IERenderer 2.4.7.2 associated with IE10 and should I have an "older" version of IERenderer co with IE9 ?[/quote]
No, it is not (I'm using IE 10 with it and so do many other people; BTW I'm using Windows 7 - 64 as well and it should allow you to install IE 10!). Please read the following post and install the MiniDump extension as advised, it should create a dump of this error which will show me what part of IERenderer's code may cause it so I can figure out the issue.
[quote user="sfleury"]Is IERenderer 2.4.7.2 associated with IE10 and should I have an "older" version of IERenderer co with IE9 ?[/quote] <p>No, it is not (I'm using IE 10 with it and so do many other people; BTW I'm using Windows 7 - 64 as well and it should allow you to install IE 10!). Please read <a href="http://community.pmail.com/forums/thread/31478.aspx" mce_href="http://community.pmail.com/forums/thread/31478.aspx" target="_blank">the following post</a> and install the MiniDump extension as advised, it should create a dump of this error which will show me what part of IERenderer's code may cause it so I can figure out the issue.</p>
 I had many pproblems with Windows 7 - 64 bits and I was even obliged to  "downgrade" from IE 10 to IE 9. I even consider to reinstall Windows !
When I start Pegasus Mail, I get an error windows that says something like there is  an error in IE Renderer 2.4.7.2
          "Attempt to revoke a depository target that was not registered (0x80040100)  @050D84F5)"
 I click on the button in the error window and can access my mail normally (read,  write...)
I downloaded the last version of IERenderer and installed it... but the problem is still there ;-(
If this is the case, where could I find it ?
Thanks  Have a good day
<font size="2"> <p align="LEFT"> I had many pproblems with Windows 7 - 64 bits and I was even obliged to  "downgrade" from IE 10 to IE 9. I even consider to reinstall Windows !</p> <p align="LEFT">When I start Pegasus Mail, I get an error windows that says something like there is  an error in IE Renderer 2.4.7.2</p> <p align="LEFT">         <strong> "Attempt to revoke a depository target that was not registered (0x80040100)  @050D84F5)"</strong></p><p align="LEFT"> I click on the button in the error window and can access my mail normally (read,  write...)</p><p align="LEFT">I downloaded the last version of IERenderer and installed it... but the problem is still there ;-(</p><p align="LEFT">Is IERenderer 2.4.7.2 associated with IE10 and should I have an "older" version of IERenderer co with IE9 ?</p><p align="LEFT">If this is the case, where could I find it ?</p><p align="LEFT">Thanks  Have a good day</p></font>
