[quote user="sfleury"]Is IERenderer 2.4.7.2 associated with IE10 and should I have an "older" version of IERenderer co with IE9 ?[/quote]
No, it is not (I'm using IE 10 with it and so do many other people; BTW I'm using Windows 7 - 64 as well and it should allow you to install IE 10!). Please read the following post and install the MiniDump extension as advised, it should create a dump of this error which will show me what part of IERenderer's code may cause it so I can figure out the issue.
<p>No, it is not (I'm using IE 10 with it and so do many other people; BTW I'm using Windows 7 - 64 as well and it should allow you to install IE 10!). Please read <a href="http://community.pmail.com/forums/thread/31478.aspx" mce_href="http://community.pmail.com/forums/thread/31478.aspx" target="_blank">the following post</a> and install the MiniDump extension as advised, it should create a dump of this error which will show me what part of IERenderer's code may cause it so I can figure out the issue.</p>
