What is your POP3 timeout value set to, in your POP3 configuration? See General tab in the POP3 Internet Mail options. This value should be at least 300 seconds, to allow for slow or fragmented download of the message from your ISP. Note that when reviewing the timeout setting, it is coded in two places, as mentioned above in the General options, and also in the POP3 settings for a specific POP3 server, which can be viewed by selecting the active POP3 definition and "editing" it. You should see a Timeout value which should be set to the same large amount.
<p>What is your POP3 timeout value set to, in your POP3 configuration? &nbsp;See General tab in the POP3 Internet Mail options. &nbsp;This value should be at least 300 seconds, to allow for slow or fragmented download of the message from your ISP. &nbsp;Note that when reviewing the timeout setting, it is coded in two places, as mentioned above in the General options, and also in the POP3 settings for a specific POP3 server, which can be viewed by selecting the active POP3 definition and "editing" it. You should see a Timeout value which should be set to the same large amount.</p><p>&nbsp;Martin</p>
