Dear Martin, thank you for introducing me to the mail merge extension. I hope you can explain a few things:
How will sending out individual messages avoid the limitations set by ISPs or ESPs? If the emails are sent out individually won't they still be counted against the 60 email/minute limit (300 emails/5 min and no more than 100 at once)? Sending it out this way I think I would have to send them manually and count out 60 emails to send each time slot.
This post has an interesting hidden Pmail feature that seems useful: http://community.pmail.com/forums/post/20109.aspx
Sending out as a distribution list also gives individual delivery failure returns. I have already set a filter to catch these into a directory to be handled. What would be very nice would be a way to extract the address from the return email and put them all in a file. What would be even better would be to be able to have the aliases looked up and removed from the distribution lists (although this is not necessary in every case.
The mail merge extension under the tools menu (and the File>New>Mail merge menu) appears to be obsolete. The new way to do it (since WPmail 4.41 I believe) is right on a tab on the New Mail window. From reading the help manual I believe I can put in the file names of the distribution lists into the data file. This is helpful in that I don't have to cut and paste them into a template individually.
How nice to know about the mail merge feature - I've never used it.
Thanks again!
<p>Dear Martin,&nbsp; thank you for introducing me to the mail merge extension.&nbsp; I hope you can explain a few things:</p><p>How will sending out individual messages avoid the limitations set by ISPs or ESPs?&nbsp; If the emails are sent out individually won't they still be counted against the 60 email/minute limit (300 emails/5 min and no more than 100 at once)?&nbsp; Sending it out this way I think I would have to send them manually and count out 60 emails to send each time slot.&nbsp;&nbsp;</p><p>This post has an interesting hidden Pmail feature that seems useful:&nbsp; http://community.pmail.com/forums/post/20109.aspx
</p><p>Sending out as a distribution list also gives individual delivery failure returns.&nbsp; I have already set a filter to catch these into a directory to be handled.&nbsp; What would be very nice would be a way to extract the address from the return email and put them all in a file.&nbsp; What would be even better would be to be able to have the aliases looked up and removed from the distribution lists (although this is not necessary in every case.
</p><p>The mail merge extension under the tools menu (and the File&gt;New&gt;Mail merge menu) appears to be obsolete.&nbsp; The new way to do it (since WPmail 4.41 I believe) is right on a tab on the New Mail window. &nbsp; From reading the help manual I believe I can put in the file names of the distribution lists into the data file. <b>This is helpful </b>in that I don't have to cut and paste them into a template individually.&nbsp; </p><p>&nbsp;How nice to know about the mail merge feature - I've never used it.
</p><p>&nbsp;Thanks again!
