It still sounds like a download controls issue. Double check the download control settings in the POP3 host configuration. Make sure the "Download only unread mail" is not checked and the "Default action for messages still present after filtering" is set to Download.
Also, enable internet session logging then check a log to see if an abnormal end to the connection is occurring. Read the help file about internet session logging if you are unfamiliar with what gets logged and/or where to find the log files.
<p>It still sounds like a download controls issue.&nbsp; Double check the download control settings in the POP3 host configuration.&nbsp; Make sure the "Download only unread mail" is not checked and the "Default action for messages still present after filtering" is set to Download.</p><p>Also, enable internet session logging then check a log to see if an abnormal end to the connection is occurring.&nbsp; Read the help file about internet session logging if you are unfamiliar with what gets logged and/or where to find the log files.
</p><p>&nbsp;</p>
