I don't normally even have my sound turned on while computing, so I have no clue how long this has happened (how many releases)
When I close a folder it beeps. Cute little "beep" like I might hear if there is a message waiting on my phone. It seems to happen no matter which folder is closed. I checked Windows sounds and it says "no sounds" and I cannot get the same response outside of the program anyway. Nope, not using New Mail sound either - it's turned off. The help file only talks about New Mail sound - it doesn't mention any "folder close" sound.
Copyright (C) 1992-2011, David Harris, all rights reserved
WinPMail version: Version 4.63 (Win32), Dec 22 2011, build ID 325
User name and ID: Liz, 0
Windows version: 6.1
WINPMAIL.EXE directory: F:\PMAIL\Programs
Home mailbox location: F:\PMAIL\MAIL\Liz
New mailbox location: F:\PMAIL\MAIL\Liz
TMP environment variable: C:\Users\Liz\AppData\Local\Temp
TEMP environment variable: C:\Users\Liz\AppData\Local\Temp
- WINSOCK path: C:\Windows\system32\WSOCK32.DLL
Commandline: -I Liz
Active -Z options: 32768
PMR variable: (None)
PML variable: (None)
MAI variable: (None)
NB variable: (None)
Autofiltering folders: 29 (29 active, 0 inactive)
Last new mail count: 0
<p>I don't normally even have my sound turned on while computing, so I have no clue how long this has happened (how many releases)</p><p>&nbsp;</p><p>When I close a folder it beeps.&nbsp; Cute little "beep" like I might hear if there is a message waiting on my phone. It seems to happen no matter which folder is closed. I checked Windows sounds and it says "no sounds" and I cannot get the same response outside of the program anyway.&nbsp; Nope, not using New Mail sound either - it's turned off. The help file only talks about New Mail sound - it doesn't mention any "folder close" sound.</p><p>&nbsp;</p><p>Pegasus Mail for Microsoft Windows
&nbsp; - WINSOCK version: WinSock 2.0
&nbsp; - WINSOCK path: C:\Windows\system32\WSOCK32.DLL
Commandline: -I Liz
NB variable: (None)
&nbsp;</p><p>&nbsp;</p>
