Hi there,
This is a known problem with this company's invoices. It should only happen if you are using Bearhtml to do the html rendering. To prove this out, while viewing this message, key in Shift + Ctrl + R which will turn off rendering of CSS content in the message. Close and re-open the message and it should appear correctly formatted.
HTH
<p>Hi there,</p><p>&nbsp; &nbsp;This is a known problem with this company's invoices. It should only happen if you are using Bearhtml to do the html rendering. To prove this out, while viewing this message, key in Shift + Ctrl + R which will turn off rendering of CSS content in the message. Close and re-open the message and it should appear correctly formatted.</p><p>HTH</p><p>Martin&nbsp;</p>
