Graphics in Incoming Message not Displaying Properly
Hi there,
   This is a known problem with this company's invoices. It should only happen if you are using Bearhtml to do the html rendering. To prove this out, while viewing this message, key in Shift + Ctrl + R which will turn off rendering of CSS content in the message. Close and re-open the message and it should appear correctly formatted.
HTH
<p>Hi there,</p><p>   This is a known problem with this company's invoices. It should only happen if you are using Bearhtml to do the html rendering. To prove this out, while viewing this message, key in Shift + Ctrl + R which will turn off rendering of CSS content in the message. Close and re-open the message and it should appear correctly formatted.</p><p>HTH</p><p>Martin </p>
This is an invoice I received from Newegg.
As you can see, the critical information is only partially
shown.  I can cut and paste and see all the info, but it is
not in the right format.
Is that a fault of my settings or the fault of
their invoice format?
I have my mail set to show the "fancy
version".
This is weird!!  When I preview this post, it doesn't show anything but the subject.
Am I doing something wrong?
<div align="left"><font face="Verdana" size="5"><span style=" font-size:20pt">This is an invoice I received from Newegg.  As you can see, the critical information is only partially shown.  I can cut and paste and see all the info, but it is not in the right format.</span></font></div> <div align="left"><font face="Verdana" size="5"><span style=" font-size:20pt"> </span></font></div> <div align="left"><span style="font-size: 20pt; font-family: Verdana;">Is that a fault of my settings or the fault of their invoice format?</span></div> <div align="left"><font face="Verdana" size="5"><span style=" font-size:20pt"> </span></font></div> <div align="left"><font face="Verdana" size="5"><span style=" font-size:20pt">I have my mail set to show the "fancy version". </span></font></div><div align="left"> </div><div align="left"><font face="Verdana" size="5"><span style=" font-size:20pt">This is weird!!  When I preview this post, it doesn't show anything but the subject. </span></font></div><div align="left"><font face="Verdana" size="5"><span style=" font-size:20pt">Am I doing something wrong?</span></font></div><div align="left"> </div><div align="left"> </div>
[quote user="desertjim"]Am I doing something wrong?[/quote]
Try opening the message (from the context menu popping up when right-clicking into non-image part) the message in your browser if you're sure it isn't a spam mail: This should either look better or fail in there as well so you can tell who's at fault here. For fixing anything if it can be fixed at all we would need to take a look at the raw HTML part of the message.
<p>[quote user="desertjim"]<span style=" font-size:20pt"><font size="2">Am I doing something wrong?</font></span>[/quote]</p><p>Try opening the message (from the context menu popping up when right-clicking into non-image part) the message in your browser if you're sure it isn't a spam mail: This should either look better or fail in there as well so you can tell who's at fault here. For fixing anything if it can be fixed at all we would need to take a look at the raw HTML part of the message.</p>
