It doesn't matter in which folder the copy to self is ... Pegasus shows the recipient due to the special format of his copy to self. For me it works in every IMAP-Folder. Have a look at the raw text.
If you generate a outgoing copy with another mailreader on same IMAP-Mailbox, that mailreader will generate a simple copy of that mail in SENT. For Pegasus this is a normal mail - no copy to self.
Note: Copy to Self with Pegasus is not the same as Outgoing Copy with any other mailreader.
bye Olaf
<p>It doesn't matter in which folder the copy to self is ... Pegasus shows the recipient due to the special format of his copy to self. For me it works in every IMAP-Folder. Have a look at the raw text.</p><p>If you generate a outgoing copy with another mailreader on same IMAP-Mailbox, that mailreader will generate a simple copy of that mail in SENT. For Pegasus this is a normal mail - no copy to self.
</p><p> Note: Copy to Self with Pegasus is not the same as Outgoing Copy with any other mailreader.</p><p>bye &nbsp; Olaf</p><p>&nbsp;</p>
