Problem with pop3
What you could do is go to File and select Selective download to see if there are any problematic messages (with an excessively large attachment for example) waiting to be downloaded. If there are, you can remove them from the pop server, and download the rest of the messages as normal. Hope this helps.
Heyho,
 I just encountered the following  problem: a user has Pegasus Mail on his pc and uses a mailbox. In this mailbox there are correct internet settings for po3 and smtp which worked fine until today. Now when he tries to fetch mail, you see Pegasus starting to do that via pop3. Butt it gets stuck upon geting the first mail. There is no error thrown, it just reports "getting new Mail 1/xx" (where xx is the number of new mails available) for a while then silently stops.
I've already googled and red FAQs but didn't find anything usful so far...
plz help
Sebastian
<p>Heyho,</p><p> I just encountered the following  problem: a user has Pegasus Mail on his pc and uses a mailbox. In this mailbox there are correct internet settings for po3 and smtp which worked fine until today. Now when he tries to fetch mail, you see Pegasus starting to do that via pop3. Butt it gets stuck upon geting the first mail. There is no error thrown, it just reports "getting new Mail 1/xx" (where xx is the number of new mails available) for a while then silently stops.</p><p>I've already googled and red FAQs but didn't find anything usful so far...</p><p>plz help</p><p>Sebastian </p>
