4.70 Two IMAP problems / editor question
BTW: IMAP is still being worked on (one of the reasons delaying the release of 5.x).
I'm using PMail 4.70 with IMAP, running PMail with Michael's PMDebug/Minidump program. When I close the IMAP connection, about half the time - and I can't yet predict when - PMDebug creates a crash dump. Hardly a major problem, but I have to ignore or delete the saved message next time I close and open PMail.
My IMAP mailbox has a large number of nested folders. When I open up the tree under a folder by clicking on the plus sign, I sometimes open up apparent multiple copies (between 2 and 5) of each subfolder in the folder pane. I can't reproduce this reliably; it may involve double- or multiple clicking of the mouse, and it occasionally happened with previous versions of PMail as well. But my impression is that it's easier to do now. Again, no more than a minor annoyance.
Finally, a question. Is the problem with cursor position after line-wrapping likely to be still present? This was a bug in the TER editor, as I recall, and it could be a serious annoyance. I haven't seen it yet, but maybe I've just been lucky so far with 4.70.
best
David
<p>I'm using PMail 4.70 with IMAP, running PMail with Michael's PMDebug/Minidump program. When I close the IMAP connection, about half the time - and I can't yet predict when - PMDebug creates a crash dump. Hardly a major problem, but I have to ignore or delete the saved message next time I close and open PMail. </p><p>My IMAP mailbox has a large number of nested folders. When I open up the tree under a folder by clicking on the plus sign, I sometimes open up apparent multiple copies (between 2 and 5) of each subfolder in the folder pane. I can't reproduce this reliably; it may involve double- or multiple clicking of the mouse, and it occasionally happened with previous versions of PMail as well. But my impression is that it's easier to do now. Again, no more than a minor annoyance. </p><p>Finally, a question. Is the problem with cursor position after line-wrapping likely to be still present? This was a bug in the TER editor, as I recall, and it could be a serious annoyance. I haven't seen it yet, but maybe I've just been lucky so far with 4.70.</p><p>best David </p><p> </p>
[quote user="David_himself"]Finally, a question. Is the problem with cursor position after line-wrapping likely to be still present? This was a bug in the TER editor, as I recall, and it could be a serious annoyance. I haven't seen it yet, but maybe I've just been lucky so far with 4.70.[/quote]
What issue are you referring to? TER/HTS haven't been updated since 4.63.
<p>[quote user="David_himself"]Finally, a question. Is the problem with cursor position after line-wrapping likely to be still present? This was a bug in the TER editor, as I recall, and it could be a serious annoyance. I haven't seen it yet, but maybe I've just been lucky so far with 4.70.[/quote]</p><p>What issue are you referring to? TER/HTS haven't been updated since 4.63.</p>
http://community.pmail.com/forums/thread/27582.aspx
OK, so I'll have to keep a close eye on edited emails before sending them. I didn't mean to sound ungrateful for 4.70: on the contrary. It's a great step forward.
David
<p>http://community.pmail.com/forums/thread/27582.aspx</p><p>OK, so I'll have to keep a close eye on edited emails before sending them. I didn't mean to sound ungrateful for 4.70: on the contrary. It's a great step forward.</p><p>David </p><p> </p>
