Okay, I have twice managed to cause Pegasus to terminate abnormally this morning. I have assumed that the MiniDump process is always running, but it appears not to have caught anything.
The trick to cause Pegasus to terminate abnormally is to wait a couple of seconds between selecting "End check" and "Cancel". Once "Cancel" has been selected, progress of the message transmission process shown in the status window at the bottom left hand corner of the Pegasus window is halted until after answering the "Are you sure that you want to discard message" prompt. After answering this prompt, and it doesn't matter whether it is answered by "Yes" or "No", the message transmission process completes and Pegasus exits. When Pegasus is re-started, it indicates that there was an abnormal termination of the previous session, but MiniDump does not indicate that there is data to send.
As stated several times, the worst aspect of this situation is that the message is sent anyway, regardless of attempts to cancel it. This can lead to an embarrassing situation because the recipient can receive a message containing errors or plain wrong information.
Upon further reflection on this problem, it is obvious that it goes away when the "Don't send" button is always available. There is then no need to attempt brute force procedures to cancel message transmission. These don't seem to work anyway, unless one takes the Task Manager route to terminate Pegasus.
It's up to you whether you deem it worthwhile to pursue this problem.
<p>Okay, I have twice managed to cause Pegasus to terminate abnormally this morning. I have assumed that the MiniDump process is always running, but it appears not to have caught anything.
</p><p>&nbsp;</p><p>The trick to cause Pegasus to terminate abnormally is to wait a couple of seconds between selecting "End check" and "Cancel".&nbsp; Once "Cancel" has been selected, progress of the message transmission process shown in the status window at the bottom left hand corner of the Pegasus window is halted until after answering the <font face="Arial" size="2"><span style="FONT-SIZE:10pt;">"Are you sure that you want to discard message" prompt.&nbsp; After answering this prompt, and it doesn't matter whether it is answered by "Yes" or "No", the message transmission process completes and Pegasus exits.&nbsp; When Pegasus is </span></font><font face="Arial" size="2"><span style="FONT-SIZE:10pt;">re-started, it indicates that there was an abnormal termination of the previous session, but MiniDump does not indicate that there is data to send.</span></font></p><p>&nbsp;</p><p>As stated several times, the worst aspect of this situation is that the message is sent anyway, regardless of attempts to cancel it.&nbsp; This can lead to an embarrassing&nbsp; situation because the recipient can receive a message containing errors or plain wrong information.
</p><p>&nbsp;</p><p>Upon further reflection on this problem, it is obvious that it goes away when the "Don't send" button is always available.&nbsp; There is then no need to attempt brute force procedures to cancel message transmission.&nbsp; These don't seem to work anyway, unless one takes the Task Manager route to terminate Pegasus.</p><p>&nbsp;</p><p>It's up to you whether you deem it worthwhile to pursue this problem.
