Go to Tools | Internet Options | Sending (SMTP) | Edit | Security
That's the Security tab. At the bottom of that box you'll see the "Do not use CRAM-MD5 authentication even if it is advertised." Check that box.
<p>Go to Tools | Internet Options | Sending (SMTP) | Edit | Security</p><p>That's the Security tab. &nbsp;At the bottom of that box you'll see the &nbsp;"Do not use CRAM-MD5 authentication even if it is advertised." Check that box. &nbsp;</p><p>&nbsp;</p><p>&nbsp;</p><p><span style="font-size: 10pt;">&nbsp;</span></p>
