help 3
Go to Tools | Internet Options | Sending (SMTP) | Edit | Security
That's the Security tab.  At the bottom of that box you'll see the  "Do not use CRAM-MD5 authentication even if it is advertised." Check that box.
<p>Go to Tools | Internet Options | Sending (SMTP) | Edit | Security</p><p>That's the Security tab.  At the bottom of that box you'll see the  "Do not use CRAM-MD5 authentication even if it is advertised." Check that box.  </p><p> </p><p> </p><p><span style="font-size: 10pt;"> </span></p>
