security issue or a regular connection?
Nothing 'normal' about these connections.
The first IP address is in Spamhaus and other DNSBLs so you could block that easily. The second isn't - yet.
Neither are doing anything but filling up your session log.
<P>Nothing 'normal' about these connections.</P> <P>The first IP address is in Spamhaus and other DNSBLs so you could block that easily. The second isn't - yet.</P> <P>Neither are doing anything but filling up your session log.</P>
I have since months the following entries in my session logging files:
[quote]21:20:36.875: Connection from 71.6.165.200, Fri Aug 22 21:20:36 2014<lf>
21:20:36.875: << 220-mymailserver.com ESMTP server ready.<cr><lf>220-Use of this server for unauthorised relaying of mail is forbidden.<cr><lf>220-Unsolicited Commercial E-mail ("spam") is NOT welcome here.<cr><lf>220 ALL ACCESS WILL BE MONITORED AND LOGGED.<cr><lf>
21:20:36.875: >> 8
21:20:36.875: << 501 Syntax error in parameters or arguments.<cr><lf>
21:20:36.875: >> À"À!
21:20:36.875: >> À/À+À'À#ÀÀ    ÀÀ
21:20:36.891: << 501 Syntax error in parameters or arguments.<cr><lf>
21:20:36.891: >>
21:20:41.219: 7: NB Socket read error 10054 (connection aborted by remote host)
21:20:41.219: --- Connection closed normally at Fri Aug 22 21:20:41 2014. ---
21:20:41.219: [/quote]
[quote]15:48:04.845: Connection from 54.183.248.186, Thu Sep 25 15:48:04 2014<lf>
15:48:04.845: << 220-mymailserver.com ESMTP server ready.<cr><lf>220-Use of this server for unauthorised relaying of mail is forbidden.<cr><lf>220-Unsolicited Commercial E-mail ("spam") is NOT welcome here.<cr><lf>220 ALL ACCESS WILL BE MONITORED AND LOGGED.<cr><lf>
15:48:04.126: >>
15:48:04.142: << 501 Syntax error in parameters or arguments.<cr><lf>
15:48:04.142: >> ­ì™ÜÊ[€öšðì±ÞL^<cr>’×
15:48:04.142: >> À"À!
15:48:04.142: >> ÀÀ    ÀÀ
15:48:04.142: >>
15:48:24.814: --- Connection closed normally at Thu Sep 25 15:48:24 2014. ---
15:48:24.814:
Are this attempts of a normal connection or scans for servers with open Heartbleed bug?
&lt;p&gt;I have since months the following entries in my session logging files: &lt;/p&gt;&lt;p&gt;[quote]21:20:36.875: Connection from 71.6.165.200, Fri Aug 22 21:20:36 2014&amp;lt;lf&amp;gt; 21:20:36.875: &amp;lt;&amp;lt; 220-mymailserver.com ESMTP server ready.&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt;220-Use of this server for unauthorised relaying of mail is forbidden.&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt;220-Unsolicited Commercial E-mail (&quot;spam&quot;) is NOT welcome here.&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt;220 ALL ACCESS WILL BE MONITORED AND LOGGED.&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 21:20:36.875: &amp;gt;&amp;gt; 8 21:20:36.875: &amp;lt;&amp;lt; 501 Syntax error in parameters or arguments.&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 21:20:36.875: &amp;gt;&amp;gt; &Agrave;&quot;&Agrave;! 21:20:36.875: &amp;lt;&amp;lt; 501 Syntax error in parameters or arguments.&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 21:20:36.875: &amp;gt;&amp;gt; &Agrave;/&Agrave;+&Agrave;&#039;&Agrave;#&Agrave;&Agrave;&amp;nbsp;&amp;nbsp;&amp;nbsp; &Agrave;&Agrave; 21:20:36.891: &amp;lt;&amp;lt; 501 Syntax error in parameters or arguments.&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 21:20:36.891: &amp;gt;&amp;gt; 21:20:36.891: &amp;lt;&amp;lt; 501 Syntax error in parameters or arguments.&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 21:20:41.219: 7: NB Socket read error 10054 (connection aborted by remote host) 21:20:41.219: --- Connection closed normally at Fri Aug 22 21:20:41 2014. --- 21:20:41.219: [/quote]&lt;/p&gt;&lt;p&gt;... &lt;/p&gt;&lt;p&gt;[quote]15:48:04.845: Connection from 54.183.248.186, Thu Sep 25 15:48:04 2014&amp;lt;lf&amp;gt; 15:48:04.845: &amp;lt;&amp;lt; 220-mymailserver.com ESMTP server ready.&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt;220-Use of this server for unauthorised relaying of mail is forbidden.&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt;220-Unsolicited Commercial E-mail (&quot;spam&quot;) is NOT welcome here.&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt;220 ALL ACCESS WILL BE MONITORED AND LOGGED.&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 15:48:04.126: &amp;gt;&amp;gt;  15:48:04.142: &amp;lt;&amp;lt; 501 Syntax error in parameters or arguments.&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 15:48:04.142: &amp;gt;&amp;gt; &shy;&igrave;&trade;&Uuml;&Ecirc;[&euro;&ouml;&scaron;&eth;&igrave;&plusmn;&THORN;L^&amp;lt;cr&amp;gt;&rsquo;&times; 15:48:04.142: &amp;lt;&amp;lt; 501 Syntax error in parameters or arguments.&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 15:48:04.142: &amp;gt;&amp;gt; &Agrave;&quot;&Agrave;! 15:48:04.142: &amp;lt;&amp;lt; 501 Syntax error in parameters or arguments.&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 15:48:04.142: &amp;gt;&amp;gt; &Agrave;&Agrave;&amp;nbsp;&amp;nbsp;&amp;nbsp; &Agrave;&Agrave; 15:48:04.142: &amp;lt;&amp;lt; 501 Syntax error in parameters or arguments.&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 15:48:04.142: &amp;gt;&amp;gt; 15:48:04.142: &amp;lt;&amp;lt; 501 Syntax error in parameters or arguments.&amp;lt;cr&amp;gt;&amp;lt;lf&amp;gt; 15:48:24.814: --- Connection closed normally at Thu Sep 25 15:48:24 2014. --- 15:48:24.814: [/quote] &lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;&lt;p&gt;Are this attempts of a normal connection or scans for servers with open Heartbleed bug? &lt;/p&gt;
