I'm trying to set up encryption for mail sent from my clients to my MercuryS SMTP server. I've understood from other posts (and I find the same) that SSL/TLS doesn't work for MercuryS, but that STARTTLS does.
I enabled SSL/TLS on both normal and alternate ports in MercuryS. I can send mail using STARTTLS from a Nokia e71 phone, and and Android tablet, but if I try to send from Thunderbird it times out immediately and I get an error logged in Mercury:
Error -32 activating SSL session (locus 0, type 0, code 0, 'Invalid TLS extension list item header'
Background detail; I am using AUTH, with a common password for all clients and a certificate generated by Mercury. There's no problem using Thunderbird with no encryption, so I don't think there's any problem with this, and on all three clients the only thing I've changed is use of STARTTLS.
I found a thread here where this error was occurring when gmail was sending mail to MercuryS but the solution is a workaround for gmail rather than a fix. I needed to apply this, now I've enabled SSL, but I couldn't find the settings in gmail - it also looks like a poor solution as mail direct from other gmail users would still fail. I've now disabled SSL/TLS on the normal port (25) so that incoming mail is unaffected and left it on the alternate (587) since that's what I use to submit outgoing mail through.
My main reason for wanting encryption is to avoid exposing my AUTH password when using shared networks such as hotel wifi - for which the main clients will be phone or tablet; Thunderbird is mostly used on my local network, so it's not too serious (I think?) if I can't encrypt it, it just limits the choice of mobile clients.
Thanks for any advice!
<p>I'm trying to set up encryption for mail sent from my clients to my MercuryS SMTP server. I've understood from other posts (and I find the same) that SSL/TLS doesn't work for MercuryS, but that STARTTLS does.</p><p>I enabled SSL/TLS on both normal and alternate ports in MercuryS.&nbsp; I can send mail using STARTTLS from a Nokia e71 phone, and and Android tablet, but if I try to send from Thunderbird it times out immediately and I get an error logged in Mercury:
</p><blockquote><p>&nbsp; Error -32 activating SSL session (locus 0, type 0, code 0, 'Invalid TLS extension list item header'</p></blockquote><p>Background detail; I am using AUTH, with a common password for all clients and a certificate generated by Mercury. There's no problem using Thunderbird with no encryption, so I don't think there's any problem with this, and on all three clients the only thing I've changed is use of STARTTLS.</p><p>I found a thread <a href="/forums/thread/35553.aspx" mce_href="/forums/thread/35553.aspx">here</a> where this error was occurring when gmail was sending mail to MercuryS but the solution is a workaround for gmail rather than a fix. I needed to apply this, now I've enabled SSL, but I couldn't find the settings in gmail - it also looks like a poor solution as mail direct from other gmail users would still fail. I've now disabled SSL/TLS on the normal port (25) so that incoming mail is unaffected and left it on the alternate (587) since that's what I use to submit outgoing mail through.
</p><p>My main reason for wanting encryption is to avoid exposing my AUTH password when using shared networks such as hotel wifi - for which the main clients will be phone or tablet; Thunderbird is mostly used on my local network, so it's not too serious (I think?) if I can't encrypt it, it just limits the choice of mobile clients.</p><p>Thanks for any advice!
</p><p>&nbsp;</p><p>
