Hmm ... you should ask David :-)
I asume that Pegasus on close first closes the connection to your IMAP-Account and in consequence has to close the IMAP-box (in "modern" view) or all folderwindows (in "classic" view) depending on that connection. So the windowstate saved on close is only windows of local folders open. I never tried that as I swapped to "modern" view as soon as Pegasus had it available.
It seems it works as designed ...
bye Olaf
<p>Hmm ... you should ask David :-)</p><p>I asume that Pegasus on close first closes&nbsp; the connection to your IMAP-Account and in consequence has to close the IMAP-box (in "modern" view) or all folderwindows (in "classic" view) depending on that connection. So the windowstate saved on close is only windows of local folders open. I never tried that as I swapped to "modern" view as soon as Pegasus had it available.
</p><p>It seems it works as designed ... </p><p>bye &nbsp; Olaf</p><p>&nbsp;</p>
