Try checking the log files for MercuryS (the SMTP server module) and Mercury core. You should be able to determine if the delay happens during the SMTP transfer or when the message is handled by the core process (where content control, SpamHalter and ClamWall are part of the equation). If we know it's in the SMTP transfer part you could then try temporarily switching on session logging while sending the same message one more time. If there are indications of problems in the log, like long delays at some point or error messages, that will show us where to look further. If not it's most likely a pure networking or antivirus software issue.
<p>Try checking the log files for MercuryS (the SMTP server module) and Mercury core. You should be able to determine if the delay happens during the SMTP transfer or when the message is handled by the core process (where content control, SpamHalter and ClamWall are part of the equation). If we know it's in the SMTP transfer part you could then try temporarily switching on session logging while sending the same message one more time. If there are indications of problems in the log, like long delays at some point or error messages, that will show us where to look further. If not it's most likely a pure networking or antivirus software issue.</p><p>&nbsp;</p>
