[quote user="George"]I have yet to work out how to do the mail-box thing but I ave seen it mentioned ion the forum. [/quote]
Open the folder window and with it active, go to the Folder pull-down menu and select "Add mailbox to list...".  Select the directory option then enter a mailbox name and the path to that directory.  It will appear at the bottom of your folder list.
 [quote user="George"] The trickiest bits were the NOSPLIT interface jumping back to the menu after file selection with no apparent indication that the file name had been "received", and finding the .CNM files, which were (Windows 8.1) inc:/ users /my name/AppData/local/temp[/quote]
NOTSPLIT is a valuable utility but requires a bit of user effort to work with, as you found out.
<p>[quote user="George"]<span style="font-size:10pt;">I have yet to work out how to do the mail-box thing but I ave seen it mentioned ion the forum.</span> [/quote]</p><p>Open the folder window and with it active, go to the Folder pull-down menu and select "Add mailbox to list...".&nbsp; Select the directory option then enter a mailbox name and the path to that directory.&nbsp; It will appear at the bottom of your folder list.
</p><p>&nbsp;[quote user="George"] <span style="font-size: 10pt;">The trickiest bits were the NOSPLIT interface jumping back to the menu after file selection with no apparent indication that the file name had been "received", and finding the .CNM files, which were (Windows 8.1) inc:/ users /my name/AppData/local/temp</span>[/quote]</p><p>NOTSPLIT is a valuable utility but requires a bit of user effort to work with, as you found out.
