Imap4 Problems
Install the latest version of Mercury with default settings and modify only those settings that must be changed. It's important to define host name for the server and local domains correctly, so please read the information in the installer carefully, and check Mercury help or the PDF manual for additional information. It's actually a good idea to spend some time reading relevant parts of the manual.
After installation you can create accounts for your users. Your firewall will need to allow access to at least port 25 (SMTP) and port 143 (IMAP). If you want the server to be reachable from the Internet you will need to forward those ports from the device that connects to the Internet (modem/router/firewall) to the server that is running Mercury.
<p>Install the latest version of Mercury with default settings and modify only those settings that must be changed. It's important to define host name for the server and local domains correctly, so please read the information in the installer carefully, and check Mercury help or the PDF manual for additional information. It's actually a good idea to spend some time reading relevant parts of the manual. </p><p><span style="font-size: 10pt;">After installation you can create accounts for your users. Your firewall will need to allow access to at least port 25 (SMTP) and port 143 (IMAP). If you want the server to be reachable from the Internet you will need to forward those ports from the device that connects to the Internet (modem/router/firewall) to the server that is running Mercury.</span></p><p> </p>
Can you help me? I dont know how to set up the Imap4 server.
Thanks Cesan
<p>Can you help me? I dont know how to set up the Imap4 server.</p><p>Thanks Cesan</p>
