Sorry 'bout that... mea culpa.
Pmail version is 4.70, build 546
I can't find any version info in PMail for IERenderer, but I just downloaded and installed what I guess is the latest from the website you referenced (v.2.4.9.9; the new installed ierenderer.dll has a filedate of 03/24/2015). I also downloaded LibTidy.dll. I checked it vs. the original one via "Properties", and although it appears to be identical to the existing file (size and digital sig data; for some reason Win7 doesn't seem to offer CRC data as WinXP did) I copied it in anyway, renaming the existing file. (BTW, the original file has a 12/15 date; the new one is 01/15). After doing that I tried to change the cache time in IERenderer.ini from 1 day to 5, but I get an "Access Denied" message. I can probably fool with the permissions and get around that, but I suspect it's not a problem since when I reacquired the message and tried to forward it "with edit" I got exactly the same result - gray blocks instead of graphics.I tried using the instructions under "Graphics" in the "BearHlpIE-En.htm" help file, but a couple of problems... The instructions say:
"To see these graphics key in Ctrl + Shift + U, right click in the message area (not in a graphic's frame) and select Show picture or ensure that Automatically if a connection exists is selected for fetching remote graphics on Tools => Options => Message reader"
There is no "Show picture" in the drop-down box, and "Automatically if a connection exists" *is* checked. (And I suspect they only apply to received messages, not to ones being forwarded, which should use the image cache. Correct?)
One plus: I've found that I can successfully forward a message with pics if I use the "Start a new message with the messages attached" option, and it gets through to the other end when a redirect doesn't.
That's it; any other ideas? If necessary I can use the "Start a new..." option as a workaround, but it seems to me that I should be able to get the normal procedure to work if it's possible to do so.
Anyway, thanks again for the assistance, and I hope with the new info something will strike you as an "AHA!". ;-)
<p>Sorry 'bout that... mea culpa.
</p><p>Pmail version is 4.70, build 546</p><p>I can't find any version info in PMail for IERenderer, but I just downloaded and installed what I guess is the latest from the website you referenced (v.2.4.9.9; the new installed ierenderer.dll has a filedate of 03/24/2015). I also downloaded LibTidy.dll. I checked it vs. the original one via "Properties", and although it appears to be identical to the existing file (size and digital sig data; for some reason Win7 doesn't seem to offer CRC data as WinXP did) I copied it in anyway, renaming the existing file. (BTW, the original file has a 12/15 date; the new one is 01/15). After doing that I tried to change the cache time in IERenderer.ini from 1 day to 5, but I get an "Access Denied" message. I can probably fool with the permissions and get around that, but I suspect it's not a problem since when I reacquired the message and tried to forward it "with edit" I got exactly the same result - gray blocks instead of graphics.I tried using the instructions under "Graphics" in the "BearHlpIE-En.htm" help file, but a couple of problems... The instructions say:</p><p>&nbsp;"To see these graphics key in <em>Ctrl + Shift + U</em>, right click in the message area (not in a graphic's frame) and select <em>Show picture</em> or ensure that <em>Automatically if a connection exists</em> is selected for fetching remote graphics on <em>Tools =&gt; Options =&gt; Message reader"</em></p><p>There is no "Show picture" in the drop-down box, and "Automatically if a connection exists" *is* checked. (And I suspect they only apply to received messages, not to ones being forwarded, which should use the image cache. Correct?)</p><p>One plus: I've found that I can successfully forward a message with pics if I use the "Start a new message with the messages attached" option, and it gets through to the other end when a redirect doesn't.</p><p>That's it; any other ideas? If necessary I can use the "Start a new..." option as a workaround, but it seems to me that I should be able to get the normal procedure to work if it's possible to do so.</p><p>Anyway, thanks again for the assistance, and I hope with the new info something will strike you as an "AHA!". ;-)
