Win 7 Mailbox Problem
<!--[if gte mso 9]><xml> </p><p> <w:WordDocument> </p><p> <w:View>Normal</w:View> </p><p> <w:Zoom>0</w:Zoom> </p><p> <w:DoNotOptimizeForBrowser/> </p><p> </w:WordDocument> </p><p></xml><![endif]-->
Luckily NTFS sharing seems to have take care of itself in
this case and I haven’t had to do anything in folder/properties/security. All
the boxes were ticked when I looked there. At the moment my desktop is the only
Win7 machine in the house, with my wife’s desktop and two laptops still using
XP. So far I seem to have been able to avoid Homegroup and get the original XP
workgroup to work. Long may it last!
Very
many thanks to you both again.
&lt;!--[if gte mso 9]&gt;&lt;xml&gt; &lt;w:WordDocument&gt; &lt;w:View&gt;Normal&lt;/w:View&gt; &lt;w:Zoom&gt;0&lt;/w:Zoom&gt; &lt;w:DoNotOptimizeForBrowser/&gt; &lt;/w:WordDocument&gt; &lt;/xml&gt;&lt;![endif]--&gt; &lt;p class=&quot;MsoNormal&quot;&gt;Luckily NTFS sharing seems to have take care of itself in this case and I haven&rsquo;t had to do anything in folder/properties/security. All the boxes were ticked when I looked there. At the moment my desktop is the only Win7 machine in the house, with my wife&rsquo;s desktop and two laptops still using XP. So far I seem to have been able to avoid Homegroup and get the original XP workgroup to work. Long may it last!&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;&amp;nbsp;&lt;/p&gt; &lt;span style=&quot;font-size:11.0pt;mso-bidi-font-size:10.0pt;font-family:Calibri; mso-fareast-font-family:&#039;Times New Roman&#039;;mso-bidi-font-family:&#039;Times New Roman&#039;; mso-ansi-language:EN-GB;mso-fareast-language:EN-US;mso-bidi-language:AR-SA&quot;&gt;Very many thanks to you both again.&lt;/span&gt;
I’m afraid that this may be a Win 7 problem as much as one
to do with Pegasus.
I have just set up a new(ish) Win 7 desktop with Pegasus
Mail 4.7 running well.
Previously, when I was using my old XP desktop, I was able
to run Pegasus on my laptop also using the mailbox on the desktop.
My problem is getting PMail 4.7 newly installed on the
laptop to work in the same way. Although I have a Network Places link that
finds the mailbox on the desktop from the laptop (\\ELON\ADMIN)
 without any problem, whatever I do, PMail
seems unable to find it.
I’ve tried using pcconfig.exe to provide the new address,
and although this changes PMAIL.CFG to the correct address, when I start PMail all
I get it the splash screen for a moment and then nothing.
Any
suggestions would be very much appreciated.<!--[if gte mso 9]><xml> </p><p> <w:WordDocument> </p><p> <w:View>Normal</w:View> </p><p> <w:Zoom>0</w:Zoom> </p><p> <w:DoNotOptimizeForBrowser/> </p><p> </w:WordDocument> </p><p></xml><![endif]-->
&lt;!--[if gte mso 9]&gt;&lt;xml&gt; &lt;w:WordDocument&gt; &lt;w:View&gt;Normal&lt;/w:View&gt; &lt;w:Zoom&gt;0&lt;/w:Zoom&gt; &lt;w:DoNotOptimizeForBrowser/&gt; &lt;/w:WordDocument&gt; &lt;/xml&gt;&lt;![endif]--&gt; &lt;p class=&quot;MsoNormal&quot;&gt;I&rsquo;m afraid that this may be a Win 7 problem as much as one to do with Pegasus.&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;&amp;nbsp;&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;I have just set up a new(ish) Win 7 desktop with Pegasus Mail 4.7 running well.&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;&amp;nbsp;&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;Previously, when I was using my old XP desktop, I was able to run Pegasus on my laptop also using the mailbox on the desktop.&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;&amp;nbsp;&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;My problem is getting PMail 4.7 newly installed on the laptop to work in the same way. Although I have a Network Places link that finds the mailbox on the desktop from the laptop (&lt;a&gt;\\ELON\ADMIN&lt;/a&gt;) &lt;span style=&quot;mso-spacerun: yes&quot;&gt;&amp;nbsp;&lt;/span&gt;without any problem, whatever I do, PMail seems unable to find it.&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;&amp;nbsp;&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;I&rsquo;ve tried using pcconfig.exe to provide the new address, and although this changes PMAIL.CFG to the correct address, when I start PMail all I get it the splash screen for a moment and then nothing.&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;&amp;nbsp;&lt;/p&gt; &lt;span style=&quot;font-size:11.0pt;mso-bidi-font-size:10.0pt;font-family:Calibri; mso-fareast-font-family:&#039;Times New Roman&#039;;mso-bidi-font-family:&#039;Times New Roman&#039;; mso-ansi-language:EN-GB;mso-fareast-language:EN-US;mso-bidi-language:AR-SA&quot;&gt;Any suggestions would be very much appreciated.&lt;/span&gt;&lt;!--[if gte mso 9]&gt;&lt;xml&gt; &lt;w:WordDocument&gt; &lt;w:View&gt;Normal&lt;/w:View&gt; &lt;w:Zoom&gt;0&lt;/w:Zoom&gt; &lt;w:DoNotOptimizeForBrowser/&gt; &lt;/w:WordDocument&gt; &lt;/xml&gt;&lt;![endif]--&gt;
The behaviour of seeing the splash screen then nothing is indeed an indication that Pegasus Mail can not find the mailbox.  The share you set up on the desktop machine should be the root mailbox
directory (default C:\PMAIL\MAIL) and not to the mailbox directory itself.  So if you set up the share named MAIL at C:\PMAIL\MAIL on the \\ELON machine then the path in the PMAIL.CFG should look like \\ELON\MAIL\~8 (or ~N).   Note that the ~8 and ~N are substitutions for the Pegasus Mail username (~8 for usernames up to 8 characters, ~N for long usernames).  Also confirm that you can navigate to this path from the Win7 machine and can open a mailbox directory and its files (try opening a new message file (.CNM) with a text editor).
Also be aware that Pegasus Mail will not work if installed anywhere inside of a Program Files directory on Win7.
&lt;p&gt;The behaviour of seeing the splash screen then nothing is indeed an indication that Pegasus Mail can not find the mailbox.&amp;nbsp; The share you set up on the desktop machine should be the root mailbox directory (default C:\PMAIL\MAIL) and not to the mailbox directory itself.&amp;nbsp; So if you set up the share named MAIL at C:\PMAIL\MAIL on the \\ELON machine then the path in the PMAIL.CFG should look like \\ELON\MAIL\~8 (or ~N).&amp;nbsp;&amp;nbsp; Note that the ~8 and ~N are substitutions for the Pegasus Mail username (~8 for usernames up to 8 characters, ~N for long usernames).&amp;nbsp; Also confirm that you can navigate to this path from the Win7 machine and can open a mailbox directory and its files (try opening a new message file (.CNM) with a text editor).&amp;nbsp; &lt;/p&gt;&lt;p&gt;Also be aware that Pegasus Mail will not work if installed anywhere inside of a Program Files directory on Win7. &lt;/p&gt;
Many thanks for that Brian and I've now set the link to \\ELON\MAIL which has duly changed PMAIL.CFG to \\ELON\MAIL (twice). However there is no \~8 (or \~N) following this and I still get the same problem when I start the program. Looking in PMAIL.INI in the mailbox I see that my Internal username is set to Admin, so can I just edit PMAIL.CFG to include \~8?
If I open the mailbox from Explorer using the link \\ELON\MAIL I can then click through to ADMIN and open *.CMN files in Notepsd without any problem BUT ... the initial link to MAIL is very slow, taking several seconds  to load. Is it possible that Pegasus is timing out? And if so can I set a longer timeout in Pegasus?
&lt;p&gt;Many thanks for that Brian and I&#039;ve now set the link to \\ELON\MAIL which has duly changed PMAIL.CFG to \\ELON\MAIL (twice). However there is no \~8 (or \~N) following this and I still get the same problem when I start the program. Looking in PMAIL.INI in the mailbox I see that my Internal username is set to Admin, so can I just edit PMAIL.CFG to include \~8? &lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;&lt;p&gt;If I open the mailbox from Explorer using the link \\ELON\MAIL I can then click through to ADMIN and open *.CMN files in Notepsd without any problem BUT ... the initial link to MAIL is very slow, taking several seconds&amp;nbsp; to load. Is it possible that Pegasus is timing out? And if so can I set a longer timeout in Pegasus? &lt;/p&gt;
So you have a desktop that hosts your mail account data and you are accessing it from a laptop?
Are you running Pegasus Mail from the desktop PC or from the laptop?
Either way, make a backup of your mail data and then delete the pmail.cfg file. Next, start Pegasus Mail and it will ask you which type of installation you have (single or multi-user), and where the mailboxes are located. If you are running winpm-32.exe from the Desktop PC (i.e. across the network) you must make sure you use UNC paths to point to the location of the mail account data and not use local paths.
UNC path = \\ELON\MAIL
Local path = C:\Mail
If you are running it from the laptop you need to ensure you use UNC paths as Brian has suggested.
&lt;P&gt;So you have a desktop that hosts your mail account data and you are accessing it from a laptop?&lt;/P&gt; &lt;P&gt;Are you running Pegasus Mail from the desktop PC&amp;nbsp;or from the laptop?&lt;/P&gt; &lt;P&gt;Either way, make a backup of your mail data and then delete the pmail.cfg file. Next, start Pegasus Mail and it will ask you which type of installation you have (single or multi-user),&amp;nbsp;and where the mailboxes are located. If you are running winpm-32.exe from the Desktop PC (i.e. across the network) you must make sure you use UNC paths to point to the location of the mail account data and not use local paths.&lt;/P&gt; &lt;P&gt;UNC path = \\ELON\MAIL Local path = C:\Mail&lt;/P&gt; &lt;P&gt;If you are running it from the laptop you need to ensure you use UNC paths as Brian has suggested.&lt;/P&gt;
Thanks Greenman, the mailbox is on the desktop and I am
trying to re-establish a setup that allows me to access it from my laptop too.
I’ve tried what you recommend several times, but the laptop
still can’t find the mailbox on the desktop using the UNC address. I’ve checked
repeatedly that this is accessible from the laptop by typing \\ELON\MAIL into
Explorer. Permissions on the Desktop (Win 7) don’t seem to be the problem then.
So I have now done the following:
Used Control Panel to uninstall
Pegasus 4.7 (and the HTML renderer) on the laptop, and deleted the remaining
files at C:\PMAIL too. I notice that this still leaves entries in Registry
which point to a mailbox at C:\PMAIL\MAIL rather than \\ELON\MAIL, but I
haven’t altered these.
I’ve reinstalled Pegasus on the
laptop using Ver 4.63, which was working OK before I installed Ver 4.7 and
changed to a new desktop with WIN 7 instead of XP.
During the installation procedure
I have unchecked ‘Preconfigure a mailbox’ and taken the third option (using on
network as part of a workgroup) when prompted for a mailbox location and
entered \\ELON\MAIL as the UNC address.
When asked if I want to add an
additional user I’ve clicked Close, leaving a single entry for Admin in the
dialog box, and the program then terminates.
When re-starting the program for the first time after this I
did  get prompted for a username,
entered Admin, and got a message that that name does not exist. Now when I
start Pegasus I’m back to just getting the splash screen for a moment and then
nothing.
&lt;!--[if gte mso 9]&gt;&lt;xml&gt; &lt;w:WordDocument&gt; &lt;w:View&gt;Normal&lt;/w:View&gt; &lt;w:Zoom&gt;0&lt;/w:Zoom&gt; &lt;w:DoNotOptimizeForBrowser/&gt; &lt;/w:WordDocument&gt; &lt;/xml&gt;&lt;![endif]--&gt; &lt;p class=&quot;MsoNormal&quot;&gt;Thanks Greenman, the mailbox is on the desktop and I am trying to re-establish a setup that allows me to access it from my laptop too.&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;&amp;nbsp;&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;I&rsquo;ve tried what you recommend several times, but the laptop still can&rsquo;t find the mailbox on the desktop using the UNC address. I&rsquo;ve checked repeatedly that this is accessible from the laptop by typing \\ELON\MAIL into Explorer. Permissions on the Desktop (Win 7) don&rsquo;t seem to be the problem then. So I have now done the following:&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;&amp;nbsp;&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot; style=&quot;margin-left:36.0pt&quot;&gt;Used Control Panel to uninstall Pegasus 4.7 (and the HTML renderer) on the laptop, and deleted the remaining files at C:\PMAIL too. I notice that this still leaves entries in Registry which point to a mailbox at C:\PMAIL\MAIL rather than \\ELON\MAIL, but I haven&rsquo;t altered these.&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot; style=&quot;margin-left:36.0pt&quot;&gt;&amp;nbsp;&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot; style=&quot;margin-left:36.0pt&quot;&gt;I&rsquo;ve reinstalled Pegasus on the laptop using Ver 4.63, which was working OK before I installed Ver 4.7 and changed to a new desktop with WIN 7 instead of XP.&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot; style=&quot;margin-left:36.0pt&quot;&gt;&amp;nbsp;&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot; style=&quot;margin-left:36.0pt&quot;&gt;During the installation procedure I have unchecked &lsquo;Preconfigure a mailbox&rsquo; and taken the third option (using on network as part of a workgroup) when prompted for a mailbox location and entered &lt;a&gt;\\ELON\MAIL&lt;/a&gt; as the UNC address. &lt;/p&gt; &lt;p class=&quot;MsoNormal&quot; style=&quot;margin-left:36.0pt&quot;&gt;&amp;nbsp;&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot; style=&quot;margin-left:36.0pt&quot;&gt;When asked if I want to add an additional user I&rsquo;ve clicked Close, leaving a single entry for Admin in the dialog box, and the program then terminates.&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;&amp;nbsp;&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;When re-starting the program for the first time after this I did&lt;span style=&quot;mso-spacerun: yes&quot;&gt;&amp;nbsp; &lt;/span&gt;get prompted for a username, entered Admin, and got a message that that name does not exist. Now when I start Pegasus I&rsquo;m back to just getting the splash screen for a moment and then nothing.&lt;/p&gt;
What path is showing in PMAIL.CFG now?  I'm curious whether it contains the ~8 or ~N substitution characters.
Also, please provide the content of the Info button located in Help > About Pegasus Mail.
Finally, try running the desktop install of Pegasus Mail from the laptop and see what happens.  Sharing the desktop install would be the simplest way to go based on what you appear to be trying to accomplish (no mailbox needed on the laptop).  Obviously you will need to create a share at the \PMAIL directory.
&lt;p&gt;What path is showing in PMAIL.CFG now?&amp;nbsp; I&#039;m curious whether it contains the ~8 or ~N substitution characters. &lt;/p&gt;&lt;p&gt;Also, please provide the content of the Info button located in Help &amp;gt; About Pegasus Mail.&lt;/p&gt;&lt;p&gt;Finally, try running the desktop install of Pegasus Mail from the laptop and see what happens.&amp;nbsp; Sharing the desktop install would be the simplest way to go based on what you appear to be trying to accomplish (no mailbox needed on the laptop).&amp;nbsp; Obviously you will need to create a share at the \PMAIL directory. &lt;/p&gt;
OK.
You need to ensure that the permissions of the account you are using to access the remote share actually have Full Control permission. It sounds as though you are only person using these computers so enable the Guest account and give the Guest account full control over the top level folder that hosts your mail data.
For example, if your data is located within the Admin folder off Mail (C:\Mail\Admin) right-click the Mail folder and ensure that the Guest account has Full Control under the Sharing permissions and the Security permissions. Click OK when done to ensure that the permissions propagate throughout the Mail and Admin folders then delete pmail.cfg and run Pegasus Mail again and point it at the Mail folder (remember to use a UNC path). When you do, you should see your Admin account listed.
Follow Brian's request too so we can see what the path is in the cfg before you delete it.
Let us know how you get on.
&lt;P&gt;OK.&lt;/P&gt; &lt;P&gt;You need to ensure that the permissions of the account you are using to access the remote share actually have Full Control permission. It sounds as though you are only person using these computers so enable the Guest account and give the Guest account full control over the top level folder that hosts your mail data.&lt;/P&gt; &lt;P&gt;For example, if your data is located within the Admin folder off Mail (C:\Mail\Admin) right-click the Mail folder and ensure that the Guest account has Full Control under the Sharing permissions and the Security permissions. Click OK when done to ensure that the permissions propagate throughout the Mail and Admin folders then delete pmail.cfg and run Pegasus Mail again and point it at the Mail folder (remember to use a UNC path). When you do, you should see your Admin account listed.&lt;/P&gt; &lt;P&gt;Follow Brian&#039;s request too so we can see what the path is in the cfg before you delete it.&lt;/P&gt; &lt;P&gt;Let us know how you get on.&lt;/P&gt;
OK!
Greenman mentioned Full Control permission for Guest. (What
the hell’s that? I’m new to Win 7 and I don’t remember any such thing in XP
where I just kind of shared things) So I spent last night with Windows 7
Unleashed, which was enlightening.
This morning I obliterated all the shares that I’d
established using the Win 7 equivalent of simple file sharing. These were for
Everyone, Read and Write. I then, as the book suggests, set them up for Guest
using the Sharing Wizard. From there I used Advanced Sharing in folder
Properties to set Full Control.
Pegasus now works fine from the laptop, and without a Mail
folder on that machine, just like old times.
The only thing that puzzles me now is that the Full Control
permission set for Mail did not cascade down to Admin, which I had to set to
Full Control too. Back to WIndows 7 Unleashed this evening I suppose, but there are moments when Win 7 makes me want to chew the
carpet.
Very many thanks to Brian and Greenman for your help, which
got me there in the end, even though it was not a Pegasus problem, and I apologise
for posting a query which wouldn’t have been necessary if I’d done my homework
properly.
I’ve
only described how I set the permissions above in case someone else with the
same problem (and level of ignorance of Win 7) stumbles on the thread. Brian and
Greenman would obviously know all this very well.
&lt;!--[if gte mso 9]&gt;&lt;xml&gt; &lt;w:WordDocument&gt; &lt;w:View&gt;Normal&lt;/w:View&gt; &lt;w:Zoom&gt;0&lt;/w:Zoom&gt; &lt;w:DoNotOptimizeForBrowser/&gt; &lt;/w:WordDocument&gt; &lt;/xml&gt;&lt;![endif]--&gt; &lt;p class=&quot;MsoNormal&quot;&gt;OK!&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;&amp;nbsp; &lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;Greenman mentioned Full Control permission for Guest. (What the hell&rsquo;s that? I&rsquo;m new to Win 7 and I don&rsquo;t remember any such thing in XP where I just kind of shared things) So I spent last night with Windows 7 Unleashed, which was enlightening.&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;&amp;nbsp;&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;This morning I obliterated all the shares that I&rsquo;d established using the Win 7 equivalent of simple file sharing. These were for Everyone, Read and Write. I then, as the book suggests, set them up for Guest using the Sharing Wizard. From there I used Advanced Sharing in folder Properties to set Full Control. &lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;&amp;nbsp;&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;Pegasus now works fine from the laptop, and without a Mail folder on that machine, just like old times.&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;&amp;nbsp;&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;The only thing that puzzles me now is that the Full Control permission set for Mail did not cascade down to Admin, which I had to set to Full Control too. Back to WIndows 7 Unleashed this evening I suppose, but there are moments when Win 7 makes me want to chew the carpet.&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;&amp;nbsp;&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;Very many thanks to Brian and Greenman for your help, which got me there in the end, even though it was not a Pegasus problem, and I apologise for posting a query which wouldn&rsquo;t have been necessary if I&rsquo;d done my homework properly.&lt;/p&gt; &lt;p class=&quot;MsoNormal&quot;&gt;&amp;nbsp;&lt;/p&gt; &lt;span style=&quot;font-size:11.0pt;mso-bidi-font-size:10.0pt;font-family:Calibri; mso-fareast-font-family:&#039;Times New Roman&#039;;mso-bidi-font-family:&#039;Times New Roman&#039;; mso-ansi-language:EN-GB;mso-fareast-language:EN-US;mso-bidi-language:AR-SA&quot;&gt;I&rsquo;ve only described how I set the permissions above in case someone else with the same problem (and level of ignorance of Win 7) stumbles on the thread. Brian and Greenman would obviously know all this very well. &lt;/span&gt;
Yeah. Permissions can make your head hurt :)
I manage the IT for a company so am familiar with them and thought your issue may be a permissions problem.
As you've learnt, the Sharing Wizard does not work as expected. It is always best to use the advanced sharing option. When you set permissions they usually filter down through the sub folders. However, it is possible (and often desirable) to prevent this from happening so that you can set specific permissions on sub folders (though this usually applies to business environments) and I suspect this is what had happened with your Mail folder. If the account you were using did not have full control permission (read, write, delete, modify etc), for the Admin folder then Pegasus Mail would not be able to read it.
Anyway, really pleased you got it working :)
&lt;P&gt;Yeah. Permissions can make your head hurt :)&lt;/P&gt; &lt;P&gt;I manage the IT for a company so am familiar with them and thought your issue may be a permissions problem.&lt;/P&gt; &lt;P&gt;As you&#039;ve learnt, the Sharing Wizard does not work as expected. It is always best to use the advanced sharing option. When you set permissions they usually filter down through the sub folders. However, it is possible (and often desirable) to prevent this from happening so that you can set specific permissions on sub folders (though this usually applies to business environments) and I suspect this is what had happened with your Mail folder. If&amp;nbsp;the account you were using did not have full control&amp;nbsp;permission (read, write, delete, modify etc),&amp;nbsp;for the Admin folder then Pegasus Mail would not&amp;nbsp;be able to read it.&lt;/P&gt; &lt;P&gt;Anyway, really pleased you got it working :)&lt;/P&gt;
Win7 can be very frustrating.  Not only do you have to establish the share and its associated permissions but you also have to set NTFS permissions (via the Security tab).  On top of that MS "tried" to make it easy with "Homegroup" but that is problematic when networking Win7 to an older OS.  I ended up disabling Homegroup on my Win7 laptop in order for it to see shares my XP desktop.  Additionally, MS made the term "share" more obtuse by using it to refer both to networking shares and user shares (between users on the same PC).
&lt;p&gt;Win7 can be very frustrating.&amp;nbsp; Not only do you have to establish the share and its associated permissions but you also have to set NTFS permissions (via the Security tab).&amp;nbsp; On top of that MS &quot;tried&quot; to make it easy with &quot;Homegroup&quot; but that is problematic when networking Win7 to an older OS.&amp;nbsp; I ended up disabling Homegroup on my Win7 laptop in order for it to see shares my XP desktop.&amp;nbsp; Additionally, MS made the term &quot;share&quot; more obtuse by using it to refer both to networking shares and user shares (between users on the same PC). &lt;/p&gt;&lt;p&gt;&amp;nbsp;&lt;/p&gt;
