[quote user="RP_Joe"]So if you have a small office can  multiple people on workstations access the same mailbox?[/quote]
Yes, but not simultaneously.
[quote user="RP_Joe"]I am thinking about the webmail feature.
If we set this up to pop our addresses from the web hosting company, then two of us can process the email from the local Mercury server, using webmail.  Is that possible ?
Could two of us use a imap client? [/quote]
Yes, but with some limitations, one of which being that a simultaneous IMAP connection to the same mailbox prevents either user from being able to delete messages.
If the need is to share the same mailbox with full functionality by each user then you have no choice but to take turns.  If you just need to share messages then there are a few ways that come to mind using a multiple user configuration in Mercury.
- Use a filter in Mercury to copy messages to the second user.  Configuration can be such that it appear to recipients that replies made be each user came from the same sender.  Alternatively, the copied message could be filtered to a folder associated with a specific identity configured such that replies appear to come from the appropriate sender (assuming Pegasus Mail is the email client).  A permanent BCC in the configuration can copy the other user on all replies if that is needed.
 - Use a filter to copy messages to a directory that is added to each users folder list as an added mailbox.  One problem with this approach is that changes made by one user (like deletes) are not reflected in the other users message list until the mailbox is manually refreshed.
 - Create a public folder and filter messages to it.  Public folders are visible in the folder list to all users of the system.
A problem with the last two options is the handling of copies to self as this can not be automated if it is important that each user have access to the copies to self.  They will need to be manually directed to a copies to self folder in an added mailbox or to a second public folder (public folders can not contain trays).  Obviously the best option depends on the ultimate goal of the sharing.
        <p>[quote user="RP_Joe"]So if you have a small office can&nbsp; multiple people on workstations access the same mailbox?[/quote]</p><p>Yes, but not simultaneously.
</p><p>[quote user="RP_Joe"]I am thinking about the webmail feature.&nbsp; </p><p>If we set this up to pop our addresses from the web hosting company, then two of us can process the email from the local Mercury server, using webmail.&nbsp; Is that possible ? </p><p>Could two of us use a imap client? [/quote]</p><p>Yes, but with some limitations, one of which being that a simultaneous IMAP connection to the same mailbox prevents either user from being able to delete messages.&nbsp; </p><p>If the need is to share the same mailbox with full functionality by each user then you have no choice but to take turns.&nbsp; If you just need to share messages then there are a few ways that come to mind using a multiple user configuration in Mercury.
</p><ul><li>Use a filter in Mercury to copy messages to the second user.&nbsp; Configuration can be such that it appear to recipients that replies made be each user came from the same sender.&nbsp; Alternatively, the copied message could be filtered to a folder associated with a specific identity configured such that replies appear to come from the appropriate sender (assuming Pegasus Mail is the email client).&nbsp; A permanent BCC in the configuration can copy the other user on all replies if that is needed.
</li><li>Use a filter to copy messages to a directory that is added to each users folder list as an added mailbox.&nbsp; One problem with this approach is that changes made by one user (like deletes) are not reflected in the other users message list until the mailbox is manually refreshed.
</li><li>Create a public folder and filter messages to it.&nbsp; Public folders are visible in the folder list to all users of the system.
</li></ul><p>A problem with the last two options is the handling of copies to self as this can not be automated if it is important that each user have access to the copies to self.&nbsp; They will need to be manually directed to a copies to self folder in an added mailbox or to a second public folder (public folders can not contain trays).&nbsp; Obviously the best option depends on the ultimate goal of the sharing.
