I have been running Pegasus for a long time now, the last three years on Win 7, just fine with only minor problems.
Then I upgraded from Windows 7 64 bit to Windows 10. Unfortunately the 32 bit variant got installed. Still Pegasus was running fine.
Yesterday I reinstalled my Windows completely new and now it is Windows 10 Pro 64 bit. Since then I have been unable to run Pegasus properly. It shows up in the task bar and the tray icon is there also. But I cannot switch to Pegasus. Alt-Tab shows a preview that looks fine, and as soon as I click it the task bar entry shows it becomes active. But no window is shown. Also trying to restore it from tray does the same. Ending Pegasus seems to send a shutdown notice to Pegasus because the next time I don't the message about a present lock file.
Is there a way to restore all the window layout to some standard? Or any other option I could try?
Thanks a lot for any help, there are mail messages from 16 years in my mailbox, I don't want to loose that.
Skar
Edit: Wow, First post and already in the wrong section. I swear I was in the Pegasus part of the forum...
<p>I have been running Pegasus for a long time now, the last three years on Win 7, just fine with only minor problems.</p><p>Then I upgraded from Windows 7 64 bit to Windows 10. Unfortunately the 32 bit variant got installed. Still Pegasus was running fine.</p><p>Yesterday I reinstalled my Windows completely new and now it is Windows 10 Pro 64 bit. Since then I have been unable to run Pegasus properly. It shows up in the task bar and the tray icon is there also. But I cannot switch to Pegasus. Alt-Tab shows a preview that looks fine, and as soon as I click it the task bar entry shows it becomes active. But no window is shown. Also trying to restore it from tray does the same. Ending Pegasus seems to send a shutdown notice to Pegasus because the next time I don't the message about a present lock file.</p><p>Is there a way to restore all the window layout to some standard? Or any other option I could try?</p><p>Thanks a lot for any help, there are mail messages from 16 years in my mailbox, I don't want to loose that.</p><p>&nbsp;Skar<span style="font-size: 10pt;">&nbsp;</span></p><p>&nbsp;</p><p>Edit: Wow, First post and already in the wrong section. I swear I was in the Pegasus part of the forum...&nbsp;</p>
