[quote user="Art Layton"]I have never run into it. It started after I had to reformat my hard drive because windows 10 corrupted some files and my computer wouldn't start..[/quote]
Sounds like your system still isn't back to normal ... I doubt anyone other than MS can help here, maybe you need to reinstall your printer drivers if this issue doesn't cease. For a start you could try installing a Generic / Text Only printer as default printer using the Windows printer setup to see whether it's caused by a corrupt printer driver.
I am getting this message in a windows pop-up box when I run Pmail. I am using windows 7 and the latest version of Pmail. Anyone have an idea what is causing this?
Pegasus Mail is dependent on a printer driver. It uses the one assigned to the default printer. If you intend to install a printer go ahead and do it now. If you aren't ready, the temporary fix is to install a printer using a generic text printer driver.
If you already have a printer installed, is it a remote printer (network, wireless)? If so, make sure it is online and accessible when running Pegasus Mail because some printer drivers poll the physical machine to make sure it is online before responding to the request by Pegasus Mail. Should this not be practical, the workaround is a generic text printer as the default printer.
[quote user="Art Layton"]I am getting this message in a windows pop-up box when I run Pmail. I am using windows 7 and the latest version of Pmail. Anyone have an idea what is causing this?[/quote]
This module seems to be necessary on 64bit versions of Windows for using a printer driver, a restart of Pegasus Mail or your system should fix this since it's loaded and unloaded by Windows when Pegasus Mail starts or finishes. Since it cannot be terminated separately unless with external tools like ProcessExplorer (advanced users only!) the reboot might become unavoidable.
More details:
Problem signature:
Problem Event Name: APPCRASH
Application Name: splwow64.exe
Application Version: 6.1.7600.16385
Application Timestamp: 4a5bd3ca
Fault Module Name: hpc6r101.dll
Fault Module Version: 0.3.1544.8561
Fault Module Timestamp: 4c9bb483
Exception Code: c0000005
Exception Offset: 0000000000075c13
OS Version: 6.1.7600.2.0.0.768.3
Locale ID: 1033
Additional Information 1: b967
Additional Information 2: b9676427d8f305a3357be0cb1920d6dc
Additional Information 3: ef7c
Additional Information 4: ef7c9ad992ecacded5025e6725746f8c
Being very curious about this I did a bit of research and found this nice explanation in a superuser.com forum post:
Short:
The process gets executed every time a 32-bit application is
accessing one of your installed printers. You could kill the process if
you are not actively printing something. It will simply restart the next
time you want to print something, e.g., from Word (which is a 32-bit
application).
Explanation:
WOW64 is the so called "Windows On Windows 64" layer which enables you to execute 32-bit applications on a 64-bit system.
This is why you have the "classic"
(where all the 64-bit binaries are being stored) and theSystem32folder for the WOW compatibility layer.SysWOW64However, 32-bit applications cannot use 64-bit binaries (and therefore also printing drivers) and vice versa.
The
is a 64-bit application, therefore ablesplwow64.exeto speak with 64-bit printing drivers and "translates" the
communication between 32-bit applications and 64-bit drivers.
I am surprised I haven't run into this given the number of 64-bit Win7 PCs here at the office printing to a variety printers from a variety of 32-bit apps. My search didn't give me the impression that this is a wide spread problem so hopefully it was just a fluke.
I have never seen it either and have a number of 64-bit Win7 PCs here at the office running a variety 32-bit apps printing to a number of different printers. Hopefully it was just a transient error for you.
