[quote]
There is no reason anyone needs to use the same cert for email as they do for other services. Try the tests at
http://www.checktls.com/perl/TestReceiver.pl which test the mail
server. And yes I know some of these have self signed certs, there are
plenty of others out there with self signed certs that work just fine.
Hmm. Would you pay for different certs for different services for the same domain? Not me. Self signed certs produce warning messages if you forgot to import them. I do not know how Mercury32 responds...
nordicsemi.no seems to be okay now but avaya.com produces a validation problem.
[quote]
TestReceiver
CheckTLS Confidence Factor for "test@nordicsemi.no": 100
MX Server |
Pref |
Con- nect |
All- owed |
Can Use |
TLS Adv |
Cert OK |
TLS Neg |
Sndr OK |
Rcvr OK |
mx01.nordicsemi.no
[194.19.86.146]
10 |
OK
(127ms)
OK
(363ms)
OK
(130ms)
OK
(127ms)
OK
(741ms)
OK
(131ms)
OK
(129ms)
OK
(131ms)
mx02.nordicsemi.no
[194.19.86.151]
20 |
OK
(128ms)
OK
(131ms)
OK
(130ms)
OK
(128ms)
OK
(675ms)
OK
(147ms)
OK
(131ms)
OK
(131ms)
Average |
| 100% |
100% |
100% |
100% |
100% |
100% |
100% |
100% |
(double click matrix to select all for copy and paste)
<caption>Run same test with:</caption>
<form action="http://www.checktls.com/perl/TestReceiver.pl" method="post">
<p> </p></form>
<p> </p></form>
<p> </p></form>
<p> </p></form>
<p> </p></form>
<p> <input id="email" name="EMAIL" class="text" value="test@nordicsemi.no" type="text"></p><p> <a href="http://www.checktls.com/testreceiver.html" class="button">Instructions</a>
</p><p> <a href="http://www.checktls.com/tests.html" class="button">About Tests</a>
</p><p> </p></form>
Note:
you can run many tests at once and/or schedule tests
with BatchTest.
Note:
use the FULL version
to test
servers with custom IP addresses, ports, authentications, and/or
timeouts.
See email policy. We will not
use addresses.
Use of
any test is explicit agreement to Acceptable Use Policy.
(double click in detail below to select all for copy and paste)
Checking test@nordicsemi.no
looking up MX hosts on domain "nordicsemi.no"
- mx01.nordicsemi.no (preference:10)
- mx02.nordicsemi.no (preference:20)
Trying TLS on mx01.nordicsemi.no[194.19.86.146] (10):
seconds |
test stage and result |
[000.127] |
Connected to server
[000.490] |
220 ironport01.nordicsemi.no ESMTP
[000.490] |
We are allowed to connect
[000.490] |
EHLO checktls.com
[000.619] |
250-ironport01.nordicsemi.no 250-8BITMIME 250-SIZE 54525952 250 STARTTLS
[000.620] |
We can use this server
[000.620] |
TLS is an option on this server
[000.620] |
STARTTLS
[000.747] |
220 Go ahead with TLS
[000.747] |
STARTTLS command works on this server
[001.324] |
SSLVersion in use: TLSv1
[001.324] |
Cipher in use: AES128-SHA
[001.324] |
Connection converted to SSL
[001.413] |
Certificate 1 of 4 in chain:
subject= /OU=Domain Control Validated/CN=*.nordicsemi.no
issuer= /C=US/ST=Arizona/L=Scottsdale/O=GoDaddy.com, Inc./OU=http://certs.godaddy.com/repository//CN=Go Daddy Secure Certificate Authority - G2
[001.438] |
Certificate 2 of 4 in chain:
subject= /C=US/ST=Arizona/L=Scottsdale/O=GoDaddy.com, Inc./OU=http://certs.godaddy.com/repository//CN=Go Daddy Secure Certificate Authority - G2
issuer= /C=US/ST=Arizona/L=Scottsdale/O=GoDaddy.com, Inc./CN=Go Daddy Root Certificate Authority - G2
[001.463] |
Certificate 3 of 4 in chain:
subject= /C=US/ST=Arizona/L=Scottsdale/O=GoDaddy.com, Inc./CN=Go Daddy Root Certificate Authority - G2
issuer= /C=US/O=The Go Daddy Group, Inc./OU=Go Daddy Class 2 Certification Authority
[001.488] |
Certificate 4 of 4 in chain:
subject= /C=US/O=The Go Daddy Group, Inc./OU=Go Daddy Class 2 Certification Authority
[001.488] |
Cert VALIDATED: ok
[001.488] |
Cert Hostname VERIFIED (mx01.nordicsemi.no = *.nordicsemi.no)
[001.489] |
EHLO checktls.com
[001.619] |
250-ironport01.nordicsemi.no 250-8BITMIME 250 SIZE 54525952
[001.620] |
TLS successfully started on this server
[001.620] |
MAIL FROM:<test@checktls.com>
[001.748] |
250 sender <test@checktls.com> ok
[001.748] |
Sender is OK
[001.749] |
RCPT TO:<test@nordicsemi.no>
[001.878] |
250 recipient <test@nordicsemi.no> ok
[001.879] |
Recipient OK, E-mail address proofed
[001.879] |
QUIT
[002.041] |
221 ironport01.nordicsemi.no
Trying TLS on mx02.nordicsemi.no[194.19.86.151] (20):
seconds |
[000.128] |
Connected to server
[000.258] |
220 ironport02.nordicsemi.no ESMTP
[000.259] |
[000.259] |
EHLO checktls.com
[000.388] |
250-ironport02.nordicsemi.no 250-8BITMIME 250-SIZE 54525952 250 STARTTLS
[000.389] |
[000.389] |
[000.389] |
STARTTLS
[000.516] |
[000.517] |
[001.088] |
[001.089] |
[001.089] |
[001.118] |
[001.142] |
[001.167] |
[001.191] |
[001.191] |
Cert VALIDATED: ok
[001.191] |
Cert Hostname VERIFIED (mx02.nordicsemi.no = *.nordicsemi.no)
[001.192] |
EHLO checktls.com
[001.338] |
250-ironport02.nordicsemi.no 250-8BITMIME 250 SIZE 54525952
[001.339] |
[001.339] |
[001.469] |
[001.470] |
Sender is OK
[001.470] |
[001.601] |
[001.601] |
[001.602] |
QUIT
[001.740] |
221 ironport02.nordicsemi.no |
[quote]
TestReceiver
CheckTLS Confidence Factor for "test@avaya.com": 90
MX Server |
Pref |
Con- nect |
All- owed |
Can Use |
TLS Adv |
Cert OK |
TLS Neg |
Sndr OK |
Rcvr OK |
p-us1-iereast.us1.avaya.com
[135.11.29.14]
100 |
OK
(4ms)
OK
(576ms)
OK
(69ms)
OK
(5ms)
FAIL
OK
(867ms)
OK
(6ms)
FAIL
de307622-de-ieremea.avaya.com
[198.152.71.104]
100 |
OK
(112ms)
OK
(1,001ms)
OK
(252ms)
OK
(107ms)
FAIL
OK
(2,044ms)
OK
(107ms)
FAIL
co300216-co-ierwest.avaya.com
[198.152.13.104]
100 |
OK
(62ms)
OK
(418ms)
OK
(89ms)
OK
(54ms)
FAIL
OK
(925ms)
OK
(54ms)
FAIL
Average |
| 100% |
100% |
100% |
100% |
0% |
100% |
100% |
0% |
Note: Cert failures do not affect TLS encryption, but may mean the site
isn't who they say they are.
<p>[quote]</p><p>There is no reason anyone needs to use the same cert for email as they do for other services.&nbsp; Try the tests at
server.&nbsp; And yes I know some of these have self signed certs, there are
plenty of others out there with self signed certs that work just fine.</p><p>[/quote]
</p><p>Hmm. Would you pay for different certs for different services for the same domain? Not me. Self signed certs produce warning messages if you forgot to import them. I do not know how Mercury32 responds...
</p><p>&nbsp;</p><p>nordicsemi.no seems to be okay now but avaya.com produces a validation problem.
</p><p>[quote]</p><h2>
TestReceiver
</h2>
<p class="cf_line">CheckTLS Confidence Factor for<b> "test@nordicsemi.no"</b>: 100</p>
<div id="Matrix">
<table class="matrix">
<tbody><tr class="toprow">
<td>MX Server</td>
<td>Pref</td>
<td>Con-
nect</td>
<td>All-
owed</td>
<td>Can
Use</td>
<td>TLS
Adv</td>
<td>Cert
OK</td>
<td>TLS
Neg</td>
<td>Sndr
OK</td>
<td>Rcvr
OK</td>
</tr>
<tr>
<td class="mx">
mx01.nordicsemi.no
[194.19.86.146]
</td>
<td class="pref">10</td>
<td class="success">
<span class="text">OK</span>
<span class="time">(127ms)</span>
</td>
<span class="time">(363ms)</span>
</td>
<span class="time">(130ms)</span>
</td>
</td>
<span class="time">(741ms)</span>
</td>
<span class="time">(131ms)</span>
</td>
<span class="time">(129ms)</span>
</td>
</td>
</tr>
<tr>
<td class="mx">
mx02.nordicsemi.no
[194.19.86.151]
</td>
<td class="pref">20</td>
<span class="time">(128ms)</span>
</td>
</td>
</td>
</td>
<span class="time">(675ms)</span>
</td>
<span class="time">(147ms)</span>
</td>
</td>
</td>
</tr>
<tr class="totalrow">
<td class="totalleftrow">Average</td>
<td>
</td><td>100%</td>
<td>100%</td>
<td>100%</td>
<td>100%</td>
<td>100%</td>
<td>100%</td>
<td>100%</td>
<td>100%</td>
</tr>
</tbody></table>
</div>
<p class="note">(double click matrix to select all for copy and paste)</p>
<table id="rerun">
<tbody><tr>
<td>
</form>
</td></tr></tbody></table><table id="rerun"><tbody><tr><td><form action="http://www.checktls.com/perl/TestReceiver.pl" method="post">
</form>
</td>
<td>
</form>
</form>
</td>
<td>
</form>
<a href="http://www.checktls.com/tests.html" class="button">About&nbsp;Tests</a>
</form>
</td>
</tr>
</tbody></table>
<p>&nbsp;</p><p class="note">
Note:
with <a href="http://www.checktls.com/batchtest.html">BatchTest</a>.
<p class="note">
Note:
use the <a href="http://www.checktls.com/perl/TestReceiver.pl?FULL">FULL version</a>
to test
timeouts.
<p class="note">
See <a href="http://www.checktls.com/policy_email.html">email policy</a>. We <em>will not</em>
use addresses.
Use of
any test is explicit agreement to <a href="http://www.checktls.com/policy_aup.html">Acceptable Use Policy</a>.
<hr class="separator">
<p class="note">(double click in detail below to select all for copy and paste)</p>
<p class="negline">
<p>Checking test@nordicsemi.no</p>
<p>looking up MX hosts on domain "nordicsemi.no"
</p><ol id="mxlist"><li>mx01.nordicsemi.no (preference:10)</li><li>mx02.nordicsemi.no (preference:20)</li></ol>
<p class="trying">Trying TLS on mx01.nordicsemi.no[194.19.86.146] (10):</p>
<table class="detail">
<th class="time">seconds</th>
<th class="tofrom">
</th>
<th class="text">test stage and result</th>
</tr>
<tr class="text">
<td class="time">[000.127]</td>
<td class="tofrom">
</td>
<td class="text">
<span class="success">Connected to server</span>
</td>
</tr>
<tr class="tome">
<td class="time">[000.490]</td>
<td class="tofrom">&lt;--</td>
<td class="text">
<span class="normal">220 ironport01.nordicsemi.no ESMTP</span>
</td>
</tr>
<tr class="text">
<td class="tofrom">
</td>
<td class="text">
<span class="success">We are allowed to connect</span>
</td>
</tr>
<tr class="fromme">
<td class="tofrom">--&gt;</td>
<td class="text">
<span class="normal">EHLO checktls.com</span>
</td>
</tr>
<tr class="tome">
<td class="time">[000.619]</td>
<td class="text">
<span class="normal">250-ironport01.nordicsemi.no
250-8BITMIME
250-SIZE 54525952
250 STARTTLS</span>
</td>
</tr>
<tr class="text">
<td class="time">[000.620]</td>
<td class="tofrom">
</td>
<td class="text">
<span class="success">We can use this server</span>
</td>
</tr>
<tr class="text">
<td class="tofrom">
</td>
<td class="text">
<span class="success">TLS is an option on this server</span>
</td>
</tr>
<tr class="fromme">
<td class="text">
<span class="normal">STARTTLS</span>
</td>
</tr>
<tr class="tome">
<td class="time">[000.747]</td>
<td class="text">
<span class="normal">220 Go ahead with TLS</span>
</td>
</tr>
<tr class="text">
<td class="tofrom">
</td>
<td class="text">
<span class="success">STARTTLS command works on this server</span>
</td>
</tr>
<tr class="text">
<td class="time">[001.324]</td>
<td class="tofrom">
</td>
<td class="text">
<span class="normal">SSLVersion in use: TLSv1</span>
</td>
</tr>
<tr class="text">
<td class="tofrom">
</td>
<td class="text">
<span class="normal">Cipher in use: AES128-SHA</span>
</td>
</tr>
<tr class="text">
<td class="tofrom">
</td>
<td class="text">
<span class="success">Connection converted to SSL</span>
</td>
</tr>
<tr class="text">
<td class="time">[001.413]</td>
<td class="tofrom">
</td>
<td class="text"> <span class="normal"> <pre class="cert">Certificate 1 of 4 in chain:
issuer= /C=US/ST=Arizona/L=Scottsdale/O=GoDaddy.com, Inc./OU=http://certs.godaddy.com/repository//CN=Go Daddy Secure Certificate Authority - G2 </pre>
</span>
</td>
</tr>
<tr class="text">
<td class="time">[001.438]</td>
<td class="tofrom">
</td>
<td class="text"> <span class="normal"> <pre class="cert">Certificate 2 of 4 in chain:
issuer= /C=US/ST=Arizona/L=Scottsdale/O=GoDaddy.com, Inc./CN=Go Daddy Root Certificate Authority - G2 </pre>
</span>
</td>
</tr>
<tr class="text">
<td class="time">[001.463]</td>
<td class="tofrom">
</td>
<td class="text"> <span class="normal"> <pre class="cert">Certificate 3 of 4 in chain:
issuer= /C=US/O=The Go Daddy Group, Inc./OU=Go Daddy Class 2 Certification Authority </pre>
</span>
</td>
</tr>
<tr class="text">
<td class="time">[001.488]</td>
<td class="tofrom">
</td>
<td class="text"> <span class="normal"> <pre class="cert">Certificate 4 of 4 in chain:
</span>
</td>
</tr>
<tr class="text">
<td class="tofrom">
</td>
<td class="text">
<span class="success">Cert VALIDATED: ok</span>
</td>
</tr>
<tr class="text">
<td class="tofrom">
</td>
<td class="text">
<span class="success">Cert Hostname VERIFIED (mx01.nordicsemi.no = *.nordicsemi.no)</span>
</td>
</tr>
<tr class="fromme">
<td class="time">[001.489]</td>
<td class="tofrom">~~&gt;</td>
<td class="text">
</td>
</tr>
<tr class="tome">
<td class="time">[001.619]</td>
<td class="tofrom">&lt;~~</td>
<td class="text">
250-8BITMIME
250 SIZE 54525952</span>
</td>
</tr>
<tr class="text">
<td class="time">[001.620]</td>
<td class="tofrom">
</td>
<td class="text">
<span class="success">TLS successfully started on this server</span>
</td>
</tr>
<tr class="fromme">
<td class="text">
<span class="normal">MAIL FROM:&lt;test@checktls.com&gt;</span>
</td>
</tr>
<tr class="tome">
<td class="time">[001.748]</td>
<td class="text">
<span class="normal">250 sender &lt;test@checktls.com&gt; ok</span>
</td>
</tr>
<tr class="text">
<td class="tofrom">
</td>
<td class="text">
<span class="success">Sender is OK</span>
</td>
</tr>
<tr class="fromme">
<td class="time">[001.749]</td>
<td class="text">
<span class="normal">RCPT TO:&lt;test@nordicsemi.no&gt;</span>
</td>
</tr>
<tr class="tome">
<td class="time">[001.878]</td>
<td class="text">
<span class="normal">250 recipient &lt;test@nordicsemi.no&gt; ok</span>
</td>
</tr>
<tr class="text">
<td class="time">[001.879]</td>
<td class="tofrom">
</td>
<td class="text">
<span class="success">Recipient OK, E-mail address proofed</span>
</td>
</tr>
<tr class="fromme">
<td class="text">
<span class="normal">QUIT</span>
</td>
</tr>
<tr class="tome">
<td class="time">[002.041]</td>
<td class="text">
<span class="normal">221 ironport01.nordicsemi.no</span>
</td>
</tr>
</tbody></table>
<p class="trying">Trying TLS on mx02.nordicsemi.no[194.19.86.151] (20):</p>
<table class="detail"><tbody><tr class="toprow">
<th class="tofrom">
</th>
</tr>
<tr class="text">
<td class="time">[000.128]</td>
<td class="tofrom">
</td>
<td class="text">
</td>
</tr>
<tr class="tome">
<td class="time">[000.258]</td>
<td class="text">
<span class="normal">220 ironport02.nordicsemi.no ESMTP</span>
</td>
</tr>
<tr class="text">
<td class="time">[000.259]</td>
<td class="tofrom">
</td>
<td class="text">
</td>
</tr>
<tr class="fromme">
<td class="text">
</td>
</tr>
<tr class="tome">
<td class="time">[000.388]</td>
<td class="text">
<span class="normal">250-ironport02.nordicsemi.no
250-8BITMIME
250-SIZE 54525952
250 STARTTLS</span>
</td>
</tr>
<tr class="text">
<td class="time">[000.389]</td>
<td class="tofrom">
</td>
<td class="text">
