How to set default window for incoming mail?
[quote user="Aimo Maileri"] P.S. Sorry, this was mailed in wrong department. Belongs to "Pegasus", not "Mercury".  [/quote]
I suggest re-posting this inquiry in the Pegasus Mail support forum where it will get the attention of the appropriate brain power.
As a starter though you can try Ctrl+W to open the IMAP new mail folder.  That key combination opens the default new mail folder.
<p>[quote user="Aimo Maileri"] P.S. Sorry, this was mailed in wrong department. Belongs to "Pegasus", not "Mercury".  [/quote]</p><p>I suggest re-posting this inquiry in the Pegasus Mail support forum where it will get the attention of the appropriate brain power.  </p><p>As a starter though you can try Ctrl+W to open the IMAP new mail folder.  That key combination opens the default new mail folder.  </p>
First, thank you for an excellent piece of software!
I have 2 incoming folders:
- one for POP, the default "New mail folder", which is no longer used at all and whose incoming account has been deleted, so it's always empty
and another
- one for IMAP, "New or unread mail (INBOX)", which is the active incoming folder and receives all incoming mail.
The problem: When I open Pegasus, the always empty POP "New mail folder" -window is always opened as the default window, so in order to get into the active incoming folder, I have to first scroll down the folder list (I have a long one) and then click open the IMAP "New or unread mail (INBOX)" open to be able to see and handle the received messages.
How can I set the IMAP window to be opened automatically by default, and not open the POP window at all?
I have already checked "ON" the defaults of the IMAP account "Always connect to this profile when Pegasus Mail starts up" and Make this definition's INBOX folder the default new mail folder", but this does not make the IMAP incoming window active.
Should I delete the "New mail" folder from under the "My mailbox" root? Or what?
best regards
Aimo Maileri
<p>Hello, First, thank you for an excellent piece of software! I have 2 incoming folders: - one for POP, the default "New mail folder", which is no longer used at all and whose incoming account has been deleted, so it's always empty and another - one for IMAP, "New or unread mail (INBOX)", which is the active incoming folder and receives all incoming mail. The problem: When I open Pegasus, the always empty POP "New mail folder" -window is always opened as the default window, so in order to get into the active incoming folder, I have to first scroll down the folder list (I have a long one) and then click open the IMAP "New or unread mail (INBOX)" open to be able to see and handle the received messages. How can I set the IMAP window to be opened automatically by default, and not open the POP window at all? I have already checked "ON" the defaults of the IMAP account "Always connect to this profile when Pegasus Mail starts up" and Make this definition's INBOX folder the default new mail folder", but this does not make the IMAP incoming window active. Should I delete the "New mail" folder from under the "My mailbox" root? Or what? best regards</p><p>Aimo Maileri </p><p> </p><p>P.S. Sorry, this was mailed in wrong department. Belongs to "Pegasus", not "Mercury". </p>
