double-click doesn't get my browser
[quote user="rgakins"]Sorry -- I meant vs. 4.73.[/quote]
Yes, 4.73 is the latest version.  You will then want to update one or both of the HTML renderers, IERenderer and Bearhtml.
IERenderer is here:  http://community.pmail.com/files/folders/community_add-ons_for_pegasus_mail/entry24145.aspx
Martin posted the url to Bearhtml earlier in this discussion.
FWIW, a couple of valuable pieces of information for us to begin helping troubleshoot your double-click problem is knowing which HTML renderer you are using and how Pegasus Mail is configured to invoke the brower.  The configuration setting is in Tools > Options > Incoming mail > Hyperlinks.  Start a new discussion if you need more info about the renderers or if you need help determining which one you are currently using.
<p>[quote user="rgakins"]Sorry -- I meant vs. 4.73.[/quote]</p><p>Yes, 4.73 is the latest version.  You will then want to update one or both of the HTML renderers, IERenderer and Bearhtml.  </p><p>IERenderer is here:  http://community.pmail.com/files/folders/community_add-ons_for_pegasus_mail/entry24145.aspx </p><p>Martin posted the url to Bearhtml earlier in this discussion. </p><p>FWIW, a couple of valuable pieces of information for us to begin helping troubleshoot your double-click problem is knowing which HTML renderer you are using and how Pegasus Mail is configured to invoke the brower.  The configuration setting is in Tools > Options > Incoming mail > Hyperlinks.  Start a new discussion if you need more info about the renderers or if you need help determining which one you are currently using.</p><p> </p>
When I double-click on a blank area representing a link to a URL,
it takes me to my PMAIL Programs folder instead of the web site.
I can right-click, "Open Link in Browser," select my browser and
be taken to the URL. This started in the last couple of weeks.
Pegasus 4.72.572, Win10
<p>When I double-click on a blank area representing a link to a URL,</p><p>it takes me to my PMAIL Programs folder instead of the web site.</p><p>I can right-click, "Open Link in Browser," select my browser and</p><p>be taken to the URL. This started in the last couple of weeks. </p><p>Pegasus 4.72.572, Win10 </p><p> </p><p> </p>
[quote user="rgakins"]Pegasus 4.72.572, Win10 [/quote]
Sorry to hear, who ever you are, "rgakins", but there are so many factors involved that it is usually pretty difficult to figure out what causes it. It's very likely that some system or browser update was involved, but since we don't know which one you're using as your default it's hard to tell what might help. Additionally you're not using the most recent versions neither of Pegasus Mail and most likely of it's HTML renderers, I assume, and: I'm constantly working on some of these issues as well at least on IERenderer.
So for now I would recommend to install the latest versions of Pegasus Mail and at least the HTML renderer you prefer and tell us which browser you're using and whether it's your system default and how it's configured in Pegasus Mail so we can figure out what might be the next steps to take.
<p>[quote user="rgakins"]Pegasus 4.72.572, Win10 [/quote]</p><p>Sorry to hear, who ever you are, "<b>rgakins",</b> but there are so many factors involved that it is usually pretty difficult to figure out what causes it. It's very likely that some system or browser update was involved, but since we don't know which one you're using as your default it's hard to tell what might help. Additionally you're not using the most recent versions neither of Pegasus Mail and most likely of it's HTML renderers, I assume, and: I'm constantly working on some of these issues as well at least on IERenderer.</p><p>So for now I would recommend to install the latest versions of Pegasus Mail and at least the HTML renderer you prefer and tell us which browser you're using and whether it's your system default and how it's configured in Pegasus Mail so we can figure out what might be the next steps to take. </p>
Is vs. 4.63 the latest (final?) version of Pegasus?
My default browser is FireFox (latest update).
<p>Is vs. 4.63 the latest (final?) version of Pegasus?</p><p>My default browser is FireFox (latest update). </p>
Current version is 4.9.9.7 at  http://community.pmail.com/files/folders/pegadd/entry51413.aspx. Bearhtml is going through some major release updates as it struggles to handle Html V5,so you may need to try a different update.  Let me know please.
<p>Current version is 4.9.9.7 at  http://community.pmail.com/files/folders/pegadd/entry51413.aspx. Bearhtml is going through some major release updates as it struggles to handle Html V5,so you may need to try a different update.  Let me know please.</p><p>Martin </p>
[quote user="irelam"]
Martin, the DLL in the 4997 package is still the 4996 as you can see below (the prior is from 4997 zip package and the latter my 4996 working copy):
Sigcheck v2.72 - File version and signature viewer
Copyright (C) 2004-2019 Mark Russinovich
Sysinternals - www.sysinternals.com
d:\downloads\temp\bear4997\Bearhtml.dll:
    Verified:    Unsigned
    Link date:    19:22 19/06/1992
    Publisher:    n/a
    Company:    Martin Ireland
    Description:    BearHtml.dll for Pegasus Mail
    Product:    n/a
    Prod version:    1.0.0.0
    File version:    4.9.9.6
    MachineType:    32-bit
    Binary Version:    4.9.9.6
    Original Name:    n/a
    Internal Name:    n/a
    Copyright:    Copyright®  February 2018 Martin Ireland
    Comments:    n/a
    Entropy:    6.59
    MD5:    E38C350F466C8F2BF86EA17C670D69FF
    SHA1:    3719C4FBA5648951CDFB602BADFD0BDC17F0E77F
    PESHA1:    FA230704AC6A1807692989E72CA74AC5277EE318
    PE256:    581DF4FE474BF2D3FD5E608377D145CDBFFDF3253F003EEC6409B4B35211D1F1
    SHA256:    4ECADA0E4173E636F2D394ECD87DBC81951FAA06617CDF7CBEF96A529279F88C
    IMP:    n/a
c:\pmail\programs\bearhtml.dll:
    Verified:    Unsigned
    Publisher:    n/a
    Product:    n/a
    MachineType:    32-bit
    Original Name:    n/a
    Internal Name:    n/a
    Comments:    n/a
    Entropy:    6.59
    IMP:    n/a
[quote user="irelam"]<p>Current version is 4.9.9.7 at  http://community.pmail.com/files/folders/pegadd/entry51413.aspx. Bearhtml is going through some major release updates as it struggles to handle Html V5,so you may need to try a different update.  Let me know please.</p><p>Martin </p><p>[/quote]</p><p>Martin, the DLL in the 4997 package is still the 4996 as you can see below (the prior is from 4997 zip package and the latter my 4996 working copy):</p><p> Sigcheck v2.72 - File version and signature viewer Copyright (C) 2004-2019 Mark Russinovich Sysinternals - www.sysinternals.com d:\downloads\temp\bear4997\Bearhtml.dll:     Verified:    Unsigned     Link date:    19:22 19/06/1992     Publisher:    n/a     Company:    Martin Ireland     Description:    BearHtml.dll for Pegasus Mail     Product:    n/a     Prod version:    1.0.0.0     File version:    4.9.9.6     MachineType:    32-bit     Binary Version:    4.9.9.6     Original Name:    n/a     Internal Name:    n/a     Copyright:    Copyright®  February 2018 Martin Ireland     Comments:    n/a     Entropy:    6.59     MD5:    E38C350F466C8F2BF86EA17C670D69FF     SHA1:    3719C4FBA5648951CDFB602BADFD0BDC17F0E77F     PESHA1:    FA230704AC6A1807692989E72CA74AC5277EE318     PE256:    581DF4FE474BF2D3FD5E608377D145CDBFFDF3253F003EEC6409B4B35211D1F1     SHA256:    4ECADA0E4173E636F2D394ECD87DBC81951FAA06617CDF7CBEF96A529279F88C     IMP:    n/a </p><p> Sigcheck v2.72 - File version and signature viewer Copyright (C) 2004-2019 Mark Russinovich Sysinternals - www.sysinternals.com c:\pmail\programs\bearhtml.dll:     Verified:    Unsigned     Link date:    19:22 19/06/1992     Publisher:    n/a     Company:    Martin Ireland     Description:    BearHtml.dll for Pegasus Mail     Product:    n/a     Prod version:    1.0.0.0     File version:    4.9.9.6     MachineType:    32-bit     Binary Version:    4.9.9.6     Original Name:    n/a     Internal Name:    n/a     Copyright:    Copyright®  February 2018 Martin Ireland     Comments:    n/a     Entropy:    6.59     MD5:    E38C350F466C8F2BF86EA17C670D69FF     SHA1:    3719C4FBA5648951CDFB602BADFD0BDC17F0E77F     PESHA1:    FA230704AC6A1807692989E72CA74AC5277EE318     PE256:    581DF4FE474BF2D3FD5E608377D145CDBFFDF3253F003EEC6409B4B35211D1F1     SHA256:    4ECADA0E4173E636F2D394ECD87DBC81951FAA06617CDF7CBEF96A529279F88C     IMP:    n/a  </p>
Bearhtml  4.9.6 o 4.9.7 are identical. Just download it as per my previous message above.
Let me know if it fixes your problem.  Good luck
<p>Bearhtml  4.9.6 o 4.9.7 are identical. Just download it as per my previous message above.</p><p>Let me know if it fixes your problem.  Good luck</p><p>Martin </p>
